Question about Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE Top Loader Washing Machine
Machine is empty and idle and suddenly comes alive-lights on control panel cycling thru all phases and it beeps constantly- while running a load it cycles thru temp control and beeps. like it doesnt know what temp to use. we checked water supply and it is ok - doesnt seem to matter on what cycle u choose. we unplug it between loads and didnt help -no error codes-anyone have a suggestion??
  • 15,935 Answers
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
The part number for the user interface for this model is 8564374.
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
The procedure for replacing this control board is shown in the images below.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the washer first.
http://media.fotki.com/1_p,wkgbsdrbswtkdqwxgtqsskgwtqkq,vi/ksgtwdgrtxkrrffsdss/1/1303472/5961857/image29464img-or.jpg
http://media.fotki.com/1_p,sqrbbsbrrbwrbdtxgtqsskgwtqkq,vi/kbqtdwdswxkbswddwbg/1/1303472/5961857/image23056img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 17, 2010
Washer goes thru cycle ok untill spin cycle gets error code out of balance, but machine not out of balance
That is not to say that the drum is not out of balance. Try running it empty and see if it happens.
Aug 09, 2013 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis washing machine has error code "UL" while in rising cycle and stop. Can you tell me what is the problem and how to solve it.
My Kenmore Elite Oasis washing machine will drain but not spin and it keeps jumping back and forth to different time cycles. It continually reads "UL" and I keep trying to adjust and balance the load but it does not help.
Jun 25, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My washing machine keeps flashing F1 signal i have a oasis he top loader
CHECK THE VACUUM HOSE FROM THE TUB TO THE CONTROL BOARD. YOU MIGHT WANT TO CHECK INSIDE THE TUB TOO, THERE MIGHT BE SOMETHING STUCK BY THE HOLE THAT THE VACUUM HOSE CONNECT TO AT THE TUB
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THRU IF NEEDED.
Jan 15, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Elite (Calypso washer machine) and try to run the empty cycle to clean inside. What is the best powder to use?
I personally suggest you do not use any powder only liquid detergent it lleans better and does not foul your machine it also will clean your empty machine as well Tide Cheer all are good liquid detergents
Dec 18, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite won't start
The control panel (touch panel) is faulty - and must be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Machine will not switch to drain and spin cycle
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
124 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
