Question about Sakar Cameras
Vivicam 128 F, does it have any lens protection? I put the batteries in correctly and turned it on, went through the setup. I then took a picture, viewed the picture and turned the camera off. The glass lens was still cover, unprotected from dust, dirt, etc. is this normal for this camera. I called the sakar number, gave the model #, and was told to remove batteries and reinsert to activate lens protection???Still no closure of lens glass. Does the Vivicam 128 F have ability to close lens or protect it?
SOURCE: Lens cover closed
this is easy to fix. in fact, i just did it on my camera about 2 minutes ago and came back to this post because i was originally looking for a solution myself. anyway, you have to be a little bit rough with the camera to fix it. on the outer lens cover you will notice that there is a metal cover on top of the plastic slider. you need to pry the two apart. there is some seriously sticky tape that is holding the metal cover to the plastic, so you need to be careful that you don't rip the whole thing off. once inside you will see a copper contact that (when you slide the lens cover) makes contact with another piece of metal. when i took a look at mine, it was covered in a bunch of lint. i used a q-tip to clean both contacts and then made sure that they were properly aligned. after that, i slid the lens cover back down and voila! works everytime now. use some superglue to put the metal cover back on again.
Posted on Jun 24, 2007
  • 2985 Answers
SOURCE: the camera len will not open
Sonsy customer support for this one a strange firmware problem indeed.
Posted on Jul 31, 2007
  • 4738 Answers
SOURCE: lens cover
I know this is an old post, but for those who want to fix it themselves: try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
Posted on Nov 25, 2007
SOURCE: My canon A520 lens cover don't open
lens opens about 25% . Will not close back.
Posted on Mar 23, 2008
SOURCE: how to unprotect the memory card
the problem isnt with your camera, its your memory card, and it isnt a problem at all. simple solution- take out your memory card, and on the side there is a tiny switch. all you gotta do is flip the switch. quick and easy. hope that helps anyone.
Posted on Sep 18, 2008
I have a Casio Exilim EX-Z33 and i dropped it a while ago and it continued to work (kind of, the images were a bit blurry). i took a picture five minutes ago and then turned it off. the lens went in but...
Sounds like the focus motor came loose - you need to take it apart and repair the gear that drives the lens assembly for focusing. The noise you're hearing is the motor trying to focus but since the lens cannot focus it continues to run and signals an error.
Feb 03, 2011 | Cameras
Lens error occured after taking a few pictures. I
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 30, 2010 | Nikon COOLPIX L18 Digital Camera
My Vivitar Vivicam 5388 lens will not move or shutter operate
Hi cda_graham
Usually it is a flat battery which causes this problem. You have to put in new battery once again and try.
Good luck
Oct 06, 2009 | Vivitar Cameras
Camera says "write protect" and I can't figure out what happened.
my chager to my jazzcamer hdv178 dose not work where can oreder another one?
May 18, 2009 | Olympus Camedia C-160 Digital Camera
Protect mode on vivitar vivicam 5386
hi there
this is the disc that you use in your camera correct, put the disc back into camera if so go to your camera setting like if you were going to review your pics.and go to the place where you went to lock the pictures press menu find protect again hit function settings hit select it will bring that picture back up again click function again and this will unlock it. this works for my cannon but it goes something like that hope this works for you its hard to explain but i had the camera in hand its easier do it. i just did it with my sons hope i didnt confuse u
Jan 19, 2009 | Vivitar ViviCam 5386 Digital Camera
Kodak Z740 digital camera
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Oct 08, 2008 | Kodak EasyShare Z740 Digital Camera
Vivitar ViviCam 3615 Digital Camera
i have a vivitar vivicam 3720 digital camera need sofewear
Nov 13, 2007 | Vivitar ViviCam 3615 Digital Camera
Help please
see if keeping the power button pressed continuously without
releasing keeps the camera on
Jun 15, 2006 | Vivitar ViviCam 5340s Digital Camera
Cameras Logo
42 people viewed this question
Top Sakar Cameras Experts
Steven Wander
Steven Wander
Are you a Sakar Camera Expert? Answer questions, earn points and help others
