Question about Euro-Pro EuroPro Shark Navigator Vacuum
Shark vaccum suction is coming out on the side how to fix it
Shark loss of suction hole on side
throw it away. It cannot be fixed. Shark does not make repair parts.
Sep 02, 2014 | Euro-Pro NV22 Shark Navigator Bagless...
Why is my Shark nv500 vaccum carpet brush is not spinning?
I am having the same issue. The brush won't even move when I turn it with my hand. I just posted this same question.
Aug 01, 2014 | Shark Rotator Professional Lift-Away...
Shark bag less does not have suction at the head
Check all hoses and tubes. If that work, call cust. service.
Dec 15, 2013 | Shark Navigator Bagless Upright Vacuum
Eureka vaccum purple does not have proper suction
most common issue is a blockage somewhere in the line or head.
Dec 21, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark transformer vac model ep602 will not suction from the floor brush, but will suction from the flexible hose. Dust cup and filters are clean. Do I need to replace the floor brush? Unit was purchased...
Has the floor brush ever worked for you? I thought it was broken at first too. The hose has to be inserted in the appropriate hole in the side of the machine. The hose is where all the suction comes from, when you put it in the side hole it will provide suction for the floor brush.
Oct 11, 2010 | Vacuums
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
Euro-Pro EuroPro Shark Navigator Vacuum Logo
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
