Question about Lasonic TRC-931 Cassette Boombox
Lasonic TRC-931 information?
I just wanted to know if a Lasonic TRC-931 plays audio format CDs? Does it just play tapes?
  • 1 more comment
  • fidy25gmoney Jun 18, 2009
    what is the most old school boom box out there that can play cds?
    Alright, thanks a lot
  • 10,515 Answers
It only plays Tapes.
Thanks.
Posted on Jun 18, 2009
  • taran_2005
    taran_2005 Jun 18, 2009
    Try Sony Psyc ZS-Sn10.
    Thanks.
    New Friend:
I have a lasonic trc-931 boom box that I need to clean up a little but I just noticed the analyzer sticker at the bottom of the boom box and it has the headphone emblem to but no jack because it comes with side headphone plug ups.I have never seen that phones picture unless they have the headphone plug up at the bottom and not on the side.It looks like a manufacture sticker error One of a kind Not a big deal but I haven't seen another one like it with the phones emblem and no plug up there
Posted on Jun 28, 2016
Audio formats supported by kenwood kdc 719
My older CD player accepted WAV files when I burned them as Audio CDs. (I was able to add CD-Text, even though my player can't read the text. The disc I added space between the tracks though didn't work properly.)
Then do a mastered burn (disc at once) and finalize the disc. I used CD Burner XP for burning the latest batch and Audacity to create the WAV files. I've also use Roxio Creator and Nero in the past.
I hope this helps.
(I'll admit there's one issue - I can't get the disc to stop between tracks. I was copying audio tapes to CD before more of my tapes broke.)
Apr 29, 2012 | Kenwood KDC-719 CD Player
I have a pioneer sa9800 with problems it has sound but on right channel a lot of craclin noise is heard even when it is on phono a bad leakage is heard as well any help pls?
YOUR DIFFERENTIAL AMPLIFIER IN THE FRONT END OF THE POWER AMP STAGE NEEDS TO BE CHANGED.
USUALLY THIS IS A DUAL TRANSISTOR WITH EITHER 5 OR 6 LEGS,OR AN IC WITH 8 PINS(4+4)
Aug 07, 2011 | Lasonic TRC-931 Cassette Boombox
Compatbility of product in Australia?
if you connect the boombox direct to the your mains of 240v, the appliances will blow up , to avoid that you need a step down transformer to connect the boombox before it goes into the mains source. you do not need any adapter, only if you want to use battery that is when you to swicth to 12v
May 25, 2010 | Lasonic TRC-931 Cassette Boombox
My boombox wont work when I put batteries in. It works fine when its plugged in but when I tried to play it using the batteries nothing happen. Please help. Thanks
A Lasonic 931 ? It has probably been taken apart by someone before you and may have unplugged the power feed from the battery compartment. Remove the rear panel then check the two wires that come from the battery box are connected to the circuit board.If not, then check to see where they go on the board, it`s not hard to do.Look for the little tabs they slide onto..
Jul 28, 2009 | Lasonic TRC-931 Cassette Boombox
Bose lifestyle 48 says format unsupported for audio cds
Everytime I want to play an audio cd, it says format unsupported. This is happening very often. And I have also cleaned the cds,but still there is no difference. What is the solution?
Apr 08, 2009 | Bose Lifestyle 48 System
Problems with circuitry on my trc-931 boombox
http://www.google.com/search?hl=en&q=Cassette+Drive+Belts Don't click: 6.anxijdt.com/16 link
http://www.wjoe.com/vintageandantiques.htm
http://www.studiosoundelectronics.com/cassette.htm
http://www.vintage-electronics.cc/
http://www.ceitron.com/passive/belt.html
http://www.ceitron.com/passive/passive.html
http://www.ceitron.com/order.html
http://www.metacafe.com/watch/1267468/how_to_fix_your_pioneer_cassette_deck/
http://www.fixya.com/support/t102401-cassette_player
http://www.google.com/products?hl=en&q=Cassette+Deck+Belts&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=4&ct=title
http://www.ehow.com/how_114068_troubleshoot-cassette-deck.html
http://www.fixitclub.com/Electronics/Cassette_Deck.shtml
http://www.turntableneedles.com/index.asp
Oct 27, 2008 | Lasonic TRC-931 Cassette Boombox
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Lasonic TRC-931 Cassette Boombox Logo
626 people viewed this question
Top Lasonic Audio Players & Recorders Experts
stynger007
Level 1 Expert
Joseph Hoffmann
Are you a Lasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
