Question about Canon imageRUNNER 3300 All-In-One Laser Printer
E202No. 1 mirror base HP detecting error - Canon imageRUNNER 3300 All-In-One Laser Printer
  • 21 Answers
Dc power supply board is fault
Posted on May 08, 2014
How do i remove a rear view mirror
check for a small screw at the base of the part that attaches to the windshield loosen it the mirror should slide up and off the shoe is glued to the windshield.
Oct 27, 2015 | 2007 Jeep Commander Rocky Mountain
Tip
Error codes related to Canon ir 2200/2800/3300
E000 Heater temperature fault
(fails to increase)
E001 Overheating detection error
E002 Heater temperature error (fails to reach
specific level; inadequate increase)
E003 Heater temperature error (abnormal
drop; low-temperature detection)
E007 Fixing film rotation error
E010 Main motor rotation error
E014 Fixing motor rotation error
E019 Waste toner case full, sensor error
E032 DA unit communication error
E051 Horizontal registration HP
detention error
E064 Power supply voltage error
(high-voltage error)
E100 Laser BD error
E110 Polygon motor rotation error
E202 No. 1 mirror base HP detecting error
E204 ADF image leading edge signal
detection fault (absent)
E220 Lamp ON error
E225 Standard white plate/edge white
plate read error
E240 Mcon-Dcon communication error
E243 Mcon-control panel
communication error
E248 Backup (EEPROM) error
E261 Zero-cross signal error
E302 Shading error
E315 Image data processing error
E601 Image transfer error
E602 Hard disk error
E604 Image memory fault
E605 Image memory battery fault
E606 HDD error
E674 Fax board error
E677 PDL board mounting error
E710 IPC initialization error (Rcon)
E711 IPC register error (ctrl)
E712 Communication error (with ADF)
E713 Communication error (with sorter
finisher)
E716 Communication error (with pedestal)
E717 Communication error (with ASSIST)
E719 Card reader, coin vendor
communication error
E732 Reader communication error
E733 Printer communication error
E737 SDRAM error
E740 Ethernet board error
E741 PCI bus error
E742 RIP1 board error
E743 Mcon-Rcon communication error
(Rcon detection)
E744 Language error
E746 Resolution conversion board error
E803 MPWS power supply voltage error
(low voltage error)
E805 Fan rotation error
E901 Pedestal main motor rotation error
[ADF]
E420 Back-up data read error
E421 Back-up data write error
E422 IPC error
[Saddle Finisher-G1]
E501 Communication error (Punch unit)
E505 Back-up RAM
E510 Feed motor
E514 Delivery motor
E530 Width plate shift motor
E531 Stapler motor
E532 Stapler slide motor
E537 Alignment motor
E540 Tray ascent/descent motor
E577 Paddle motor
E590 Puncher motor
E592 Puncher sensor error
E593 Puncher shift motor
E5F1 Saddle folder motor
[Finisher-J1]
E500 Communication error
E514 Stack handling motor
E530 Rear alignment motor
E531 Stapler motor
E537 Front alignment motor
E577 Delivery motor
E580 Delivery tray ascent/descent motor
E585 Stack handling error
If the thermistor has a short circuit, the indication in service mode
(COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC=250°C
for the main thermistor; FIX-E=310°C for the sub thermistor.
Error codes from E000 to E003 can be in some cases reseted from service mode: PROCEDURE:
Press*
Press2
Press8
Press*
Navigate to: COPIER>FUNCTION>CLEAR>ERR.
Turn off and on.
on Aug 03, 2010 | Office Equipment & Supplies
E studio 161 error L3
L3 occurs due to scanner trouble.
Mirror unit abnormality
Scanner wire disconnection
Origin detection sensor abnormality
Mirror motor harness abnormality
Use SIM 1-1 to check the mirror reciprocating
operations.
When the mirror does not return.
Check for disconnection of the scanner wire.
Check the harness and the connector between
the mirror motor and the MCU PWB.
When the mirror does feed.
Use SIM 1-2 to check the mirror home position
sensor.
To enter SIMULATION MODE press C, 0, reset key, C (press these four buttons as soon as posible. The display will go off then enter the SIM codes and press START)
Dec 05, 2012 | Toshiba e-Studio 161 Copier Copier
ERROR L1-00
Scanner feed trouble.
The scanner does not complete feeding in the specified time.
Mirror unit abnormality.
The scanner wire is disconnected.
The origin detection sensor abnormality.
Mirror motor harness abnormality.
Use SIM 1-1 to check the mirror reciprocatingoperations.
When the mirror does not feed.
Check the harness and the connector between the mirror motor and the MCU PWB.
Replace the mirror unit.Replace the MCU PWB.
Use SIM 1-2 to check the mirror home positionsensor.
From the service manual: http://www.scribd.com/doc/74632095/ARM206-M161-SM-GB
Oct 12, 2012 | Sharp AR-M206
We have a Sharp AL 165 1CS Copier and an error is showing. Cannot locate our manual. Error is: [L1-00]
L1; Mirror base feed trouble.
cause:-
Mirror unit defect
Mirror home position sensor defect
Check the scanning operation with
SIM 1-1.
Dec 20, 2010 | Sharp Office Equipment & Supplies
I have Sharp AR 5316 L1 00 error in my copier pls give tips urgent
L1 00 Content Scanner feed trouble.
Detail The scanner does not complete feeding in the
specified time.
Cause Mirror unit abnormality.
Check
and
remedy
operations.
Jul 28, 2010 | Sharp AR-5316 Advanced Digital Imager...
TROUBLESHOOTING ERROR CODE SC320
SC-320 Polygon mirror motor error:
Symptom: Did not detect lock signal from
polygon mirror motor within 10
seconds after motor ON signal;
or, lost lock signal for
continuous 1.5 seconds after
signal was detected.
Cause:
1.Polygon mirror motor (or harness)
defective
2.FCU defective
P.S. Remove LSU. Turn out poligon mirror.
Clean & lubricate.
Jun 19, 2009 | Ricoh Aficio 150 Copier
Error 51.10 hp 4250 printer
This is what that code means.
51.1 Laser beam detect error
Clean laser beam reference mirror and associated components or replace laser assembly the laser reference mirror in located inside the laser housing.
You are probably going to need a tech to do this.
Hope that helps...
Jun 16, 2008 | HP Office Equipment & Supplies
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
20 people viewed this question
old marine
old marine
