Question about LG Washing Machines
Manual for LG 7.2 kg WD-80130F
Will not spin
  • 10 Answers
SOURCE: lg wd-80130f
sounds like whoever changed the pump has made a hash of the wiring, get them back to it.
Posted on Feb 04, 2008
  • 136 Answers
SOURCE: LG washing machine intellowasher 7 kg wd-8050f
Please unplug or shut off the power at the fuse box...
The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valve The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valves are blocked or the solenoids do not activate, the symptoms may include no water, low water pressure, the wrong water temperature or water entering the tub even when the machine is off.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.There are two wires connected to each solenoid (aka coil) on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Posted on Jan 19, 2010
  • 5102 Answers
SOURCE: Hi, hope you can help, I have a 4 kg LG Washer /
CL means that the child lock feature is active and the control panel buttons will not respond. For the LG WD1433RD, press and hold the Rinse+ and Pre-Wash buttons together for about 3 seconds to toggle the lock off. For the LG WD14311RD, press and hold Option and Rinse for about 3 seconds. On both washers, there is a small icon between the two buttons needed to toggle the child lock feature on and off. (It's a small face above a padlock.)
The manual as a Djvu file for the LG WD14311RD is available here: http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=WD-14311RD&initialTab=warranty&targetPage=support-product-profile .
The manual for the WD1433RD is available as a PDF here: http://www.manualsonline.com/ex/thread/view/idThread/80183 .
I hope this helps.
Posted on Apr 07, 2011
Testimonial: "Simple explanation , very quick response....fantastic"
chans007
  • 66 Answers
SOURCE: My model is Intello washer
See if your washer is still under warranty ( perhaps an extended warranty?), if not unplug and remove hoses from faucets, remove back of machine, and carefully try to move the tub of washer back and forth a bit. BE GENTLE, you don't want to do any further damage. Sounds like something loosened up, you'll need some hand tools to tighten up a screw or bolt, and a good flashlight and an extra pair of hands to help with this.
Don't over tighten, if that is what has to happen.
If you are not able to repair it yourself, call a repair person so you don't damage it,
but get 5 estimates before choosing who to have repair it.
To often we pick the first one and it costs way to much $$.
If machine is still under warranty, don't attempt any repairs as that will negate your warranty.
Posted on Apr 30, 2011
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
I am looking for wa10r3 samsung washing mahine washing but wont spin,sounds as if is spinning but wont spin.please help me
check underneath for a solenoid that engages a lever or clutch to connect the belt drive to the base of the tub
it it is not slapping in when it goes to spin , it will not spin
Dec 18, 2015 | Samsung Washing Machines
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
May 15, 2014 | Whirlpool Washing Machines
Will not spin on spin cycle
Brian...You have a Non-compliant washer! Brian...You need to replace and Install a New Drain Pump! She will Spin, Spin, Spin all day long afterwards~
Jan 20, 2014 | Whirlpool Washing Machines
Not spinning on spin cycle
No spin is electrical!
Nov 28, 2012 | Washing Machines
Hi, I have SW1ASP Samsung 6 kg washing machine. Its washing but not spinning. its try to spin and motor try to pushing to spin but it spin slight and stop. When i jiggle the machine while it try to spin...
1) may be your spinning cloth load over.
2) Check inside the container (space of wall & spin tube) cloth may be inside.
3) Door stopper (Brake) position not correct.
Actually the spin motor starting slowly first.
Mar 26, 2011 | Washing Machines
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Washing Machines Logo
74 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
