Question about Garden
Cub cadet CLT160, not charging
Alternator under the flywheel tests good. Wiring harness checks out ok. I found a burned out red wire coming off the alternator, looks like it may have had a fuselink or maybe a diode. What regulates the voltage to the battery?
  • 173 Answers
SOURCE: Chevy G20 1985 wiring (charging problem)
http://wareznuke.com/apps/3872/all-1979-2007-vehicle-wiring-diagrams-v42-rapidshare-warez
Posted on Jul 08, 2009
  • 148 Answers
SOURCE: Cub Cadet 2145 doesn't have a spark
Great!
Posted on Jul 22, 2009
  • 733 Answers
SOURCE: replaced alternator on 1985 Ford Bonco 4X4 302
turn your vehicle on, disconnect the battery, both terminals(while truck is still on) if it dies on you, then either the alternator is bad or wiring is wrong. if it stays on, then you may have a bad battery or voltage regulator. Check the voltage on the battery before you turn it on(should be from 11.5v-12v), when you turn it on if the alternator if working properly you should have around 13v-14v.
Posted on Sep 16, 2009
Testimonial: "This was helpful, but I did not post that I had already performed this check."
  • 7 Answers
SOURCE: Have 2002 jeep grand cherokee
The voltage regulator is in the PCM. If there is a problem with it, the PCM has to be replaced.
Posted on Oct 03, 2010
  • 456 Answers
SOURCE: i have a voltage regulator problem. ihave gone
the voltage regulator is normally built in to the alternator, so i would have expected this to have cured the problem.
it appears to me that something else is causing the regulator to continually blow and this in turn is overcharging the battery, causing it to fail.
the only thing i can think of to check is the earth leads going from the battery to the engine and the body of the car. make sure they are tight and fixed to clean rust free metal.
i would then get the system checked by a specialist auto electrician as it will save you money in the long run
Posted on Feb 25, 2011
Have a cub cadet zero turn. Have read several things of what it might be. They are saying the charging system. Not understanding what I need to replace. Could u please help?!?!?
Rita. the charging system is several things. on the engine under the flywheel there is a magneto that charges the battery. you need to test to see if it is or is not charging. if it is ok check connections. a bad connection will keep it from charging. any and all connections. might be a broken wire . hope this will help you out.
Jun 20, 2016 | Cub Cadet Garden
Lzf6127 has diode in wiring harness, does not show in parts, is this a recall item
Its to make alt. charge. For running it and hooking wires together, burn the thing up. The parts you need under flywheel
Apr 05, 2016 | Husqvarna Garden
My john deere 14sb mower starts but kills when I engage the blade
Check your safety seat switch. Unplug the wiring harness to the switch and place a paper clip into the harness. This will bypass the switch unless you have a continuity tester to test the switch.
Aug 07, 2013 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Does a cub cadet model 2544 use a alternator to charge the battery my battery is not holding a charge alredy put in a new battery
yes it has a low amp charging system charge the battery and disconnect the neg cable install a test light between the cable and the battery if the light is on there is a draw unplug the harness that goes to the charging system if the light then goes out the diode on the charging system is bad
Aug 06, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
I need a wiring diag for a international cub cadet 782 sn#2050601u725761 mod#144782399 17hp kolher will not charge when blades are on
Here is the wiring dagram for sn's 720000-737624
http://www.cubfaq.com/wiringdiagrams/782a.jpg
Not sure why the problem manifests only when the blades are on.
Battery charging power comes from the white alternator wire on the engine thru the key switch (in run or start position) terminals R to B through the charge indicator and a fuse to a connection on the start solenoid and then to the battery. It does not go through the PTO clutch. The only thing that would make any sense is if there was a chassis wiring harness short that was being made by the position of the mower deck.
Hopefully the diagram will help you find the problem.
Thanks for choosing FixYa,
Kelly
Aug 17, 2011 | Cub Cadet Garden
Starter generator turns over slow with new full charged battery on a 124 cub cadet when trying to start. It is a new starter generator - suppose to have been tested. I have checked wiring - acts like it...
With the battery going dead on its own like that, I think you have a short circuit somewhere that is causing this problem. This could be anywhere in your wiring system so check everything out. Hope this is helpful to you. Best regards and good luck.
Jan 08, 2011 | Cub Cadet Lawn Mower Electric PTO Clutch...
CUB CADET LT 1046 WONT CRANK
If the head lights come on, check the PTO switch connector. Very often the connector comes loose.
If no headlights, check the fuse. If blowen look for shorted wiring: Mice may have chewed wires inside the flywheel cover; check the head light cable. Often it rubs through at the hood pivot; check the lead on the carburetor solenoid, sometimes they rub through at the wire ties holding the red lead to the solenoid.
I am a certified Cub service tech,and those are the common problems I have run into.
Oh, one more thing, make sure the battery is good. Load test it or have it load tested if you don't have a tester. Don't just check it with a volt meter. That wont load the battery to check for dead cells.
Jul 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
