Question about LG WD-80130F 7.2kg Washing machine
Washing machine will not spin
Plse help I have checked the incoming water filter and the filter at the bottom of the front loader
BIKER T
  • 909 Answers
SOURCE: LG Washing machine - Front Loader
simply look at manual and see what SE represents. if not available i suggest you phone nearest lg branch and ask for service dept. enquire what SE STANDS FOR THEN RECTIFY PROBLEM.
Posted on Sep 21, 2007
MNTECH
  • 1543 Answers
SOURCE: WM0532HW LG front loader washing machine displays LE
LE codes are extensively covered in past Fix-Ya solutions, but are generally caused by only a handful of things. 1. the " Load Error " can be a very off balanced load. 2. excessive use of soap leads to too much suds, and thus drag on the inner tub. (use 1 tablespoon of HE soap max. per load) or 3. the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000.
Posted on Feb 24, 2009
  • 22 Answers
SOURCE: Error Message and Tub not spinning
Depending on how many clothes are in the washer you may a unbalance error
Posted on Jul 31, 2009
SOURCE: LG WM2355C water leaking under machine after washing finished.
I had this same problem and it was not the supply connections or filters! Under the machine is a rubber bellows. The bellows had sprung a leak. The part was about $10 from Sears and I repaired it in about 30 minutes. The machine is heavy so be careful. Get a friend to make sure the machine won't rock or tip when you're making the repair.
Posted on Sep 16, 2009
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
Is there a filter on this model if so where can i find it
george
no details as to make model year top or front loader so no answers
post the question again with the details if you want an answer
May 22, 2016 | Washing Machines
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
It does not spin all the water out but you can make spin a 2 time and all of the water is gone
Sounds like you may have a restricted drain pump. Many front loaders have a filter in the front near the bottom of the machine that needs to be cleaned periodically. Be carful as opening this filter will allow any water left in the base of the machine out.
Aug 04, 2013 | Washing Machines
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Feb 03, 2013 | Washing Machines
My washing machin no drain the water everting work good
Hi.
Check the drain hose, ensure it is not kinked and check height.
Access the water pump filter. This is located in front at the bottom in most front loaders, in top loaders the pump is accessed from the back or from underneath the appliance.
Clean or replace the pressure switch.
Check if the pump is working.
Some of this troubleshooting is illustrated in the following article, dealing with no spin problem. This is because drain problems are often resulting in no-spin. See: If you have no spin there may be different reasons...
Mar 31, 2011 | Washing Machines
My front loader does not drain completely, water can be heard when i manually spin drum...how can i check the hose?
Have you checked that the filter is not blocked. The filter is normally accessible via a flap at the bottom of the front panel of the machine. Open the flap and unscrew the filter housing, withdraw the filter and clean it thoroughly.
Jan 16, 2011 | Maytag Washing Machines
Washer will not spin water out. I took clothes out of water and tried spin cycle again...still will not spin water out.
You probably have a blocked filter on the drain pump. If it is a front loader the service panel will be on the front at the bottom of the unit on the left or right. Open this up and remove the filter and check for blockages. Have a baking tray handy to collect any water.Hope this helps.
Jan 19, 2010 | Maytag Washing Machines
Front loader full of water, did the wash and won't drain or spin
It will not spin if it has water in it. you need to remove and clean the filter.
Generally speaking the filter is usually located at the bottom right front of washer.
Some times behind a removeable cover at bottom of washer.
Once you have located it, unscrew the filter anti-clickwise to remove and clean.
Hope this helps.
Dec 07, 2009 | Bosch Washing Machines
Washing machine
The filter on your pump is probably clogged with lint and other stuff. Lift washer up a bit. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. Drain off excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water or a wet vac. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Nov 27, 2007 | Whirlpool GHW9150 Front Load Washer
Washing machine
You have to check and clean out your outlet filter. This requires periodic cleaning, according to your usage. If its a front loader, the small door is at the front bottom, be prepared for water to come out while opening.
Oct 06, 2007 | Washing Machines
Washing Machines Logo
46 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
