Question about HP Inkjet 1100d Printer
Using HP 1100d Office Inkjet printer. Can't get 'out of paper' light to turn off. I have added paper, pressed the reset button, but light stays on, and printer will not operate.
  • reedm79 May 11, 2010
    Open the lid of the printer a few times.
  • 72 Answers
Please read over the following information and follow step by step.
Issue Either before or during a print job, the message ' Paper Jam ' appears on the product control panel display. The product does not output paper or complete the print job. Solution Follow these steps to resolve the issue. Step one: Remove any loose paper
  1. Remove any loose paper from the paper tray and output tray. CAUTION: Do not remove jammed paper at this stage.
  2. Press the Cancel/No button on the product control panel to clear the paper jam message.
  3. If the paper jam message cleared, try the print job again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , continue to the next step.
Step two: Clear the jam from the back of the printer
  1. Press the Power button (Using HP 1100d Office Inkjet printer.  - c01345237.gif ) to turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the rear access door: Turn the knob one-quarter turn to the left and pull the door away from the product. Figure 1: Remove the rear access door c01489996.gif
  4. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If any torn pieces of paper remain inside the device, then more paper jams are likely to occur.
Step three: Clean the rollers While the rear door is removed from the product and the power cord is disconnected, clean the paper rollers.
  1. Wipe the paper rollers with a lint-free cloth that is lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 2: Clean the Using HP 1100d Office Inkjet printer. - c00246512.jpg c00246512.jpg
  2. Allow the rollers to dry completely.
  3. Replace the rear access door. Gently push the door toward the product, and then lock it in place by turning the knob one-quarter turn to the right or locked position.
  4. Reconnect the power cord to the back oUsing HP 1100d Office Inkjet printer. - c01345237.gif.
  5. Press the Power button (c01345237.gif ) to turn on the product.
Step four: Reload paper and test the printer Load a stack of plain white paper in the paper tray and try the print job again.
  1. Press the Cancel/No button on the product control panel to clear the paper jam message.
  2. Lift the output tray.
  3. Pull out the front paper guide on the paper tray and slidUsing HP 1100d Office Inkjet printer. - c01489992.gifper guide as far to the left as it will go. Figure 3: Slide out paper guides c01489992.gif 1 - Front paper guide 2 - Side paper guide
  4. Load a stack of plain white paper, print-side down into the paper tray. Make sure the paper stack is no higher than the top of the front paper guide.
  5. Lower the output tray.
  6. Figure 5: Disengage the photo tray c01489994.gif
  7. Try the print job again.
Step five: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product. Have a good day,
Posted on Jun 18, 2009
  • 1,959 Answers
Open the back of the unit. There's a small plastic rod that senses the paper. It may be out of position or broken (more likely stuck than broken). Remove the paper and try to manipulate the rod with your finger. If you're able to move it (or remove any debris in the way), this should clear your error message. Best of luck.
Greg
My 5550laserjet hp printer showing 59.90 error
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and then turn the printer on.
  3. If the error message returns, turn the printer off.
  4. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  5. If this message persists, contact an HP-authorized service or support provider.
Check this page out as well (parts) Error Codes and Support
Dec 21, 2017 | HP Office Equipment & Supplies
Reset canon printer MP500
Call canon tech support for any of issue in printer you can them directly here is the number (877-690-9305)
Jul 26, 2014 | Canon Pixma MP500 All-In-One InkJet...
My HP Deskjet 6540 doesn't print the test page or anything else.
How do I print a test page without the printer being hooked up to a printer ?
Feb 08, 2011 | HP DeskJet 6540 InkJet Printer
HP Officejet Pro 8500 has problem with document feeder. I can reset it by turning the gear on the inside rear of the ADF door. I lift the door and spin the gear and the pull roller will drop down. Other...
Follow this steps to make it work..
SOLUTION #1 CLEAN THE ADF FEEDER 1. take out all the papers that you have on the printer 2. turn off (c01602202.gif) the printer using the power button 3. unplug/disconnect the power cable at the back of the printer 4. Lift the cover of the ADF, and then find the rollers and the separator pad.
what is separator pad?? click here
5. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth. 6. Use the damp cloth to wipe any residue off of the rollers and the separator pad. 7. Dry the rollers and separator pad with a dry, clean, lint-free cloth. 8. Close the cover of the ADF. 9. Reconnect the power cord to the rear of the product. 10. Press the Power button (c01602202.gif ) to turn on the product. 11. Reload the original document print side up in the document feeder tray. 12. Try to make a to make a copy again using the ADF, if you are still having issues with it, continue to the next step.
SOLUTION #2 RESET THE PRINTER 1. turn off the printer (c01602202.gif) 2. unplug/disconnect the power cable at the back of the printer 3. while the printer is off and unplug, on the control panel of the printer press the # and number 3 at same time (keep on pressing and wait for 1min) 4. after 1min. keep on pressing the two buttons then plug the power cable back in to the printer. 5. If the printer does not turn on, press the Power button (c01602202.gif ) to turn it on. 6. release the buttons when part NVM reset appears on the printer screen. 7. press ok, then continue the following task.
IF THIS STEPS DID NOT RESOLVED THE PROBLEM CONTACT HP PRINTERS SUPPORT DEPARTMENT 1-800-474-6836
Good luck! :)
Jan 30, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
All lights are blinking including the power button and the printer cannot be turned off. How do I resolve this issue?
hardware failure perform these resets if not work replace it
Press & hold the power button > unplug the power cable from the back of the printer while holding the button for 30 seconds > plug the cable back then release the button.
2.A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models.
Reset the All-in-One to the factory default settings by using these instructions:
1. Disconnect and then reconnect the power cord.
2. When the lights begin to flash, press and hold Cancel and Paper type.
When the Cancel/Resume light is off, release the buttons. Then press the Power button to start reset
Sep 19, 2010 | HP PSC 1510 All-In-One InkJet Printer
HP 2575 printer - paper jam message
Resetting the product may help with some false error messages. Press power button to turn printer off, unplug the power cord, wait a few seconds, plug it back in, press power button to turn printer back on. Any luck?
Dec 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Attention light blinks after jam
most of the HP printers will detect the paper jam and will provide you with help window automatically to rectify the problem. If paper gets jammed, just remove it from backside and then turn off the printer and power it on. cancel any pending printing documents. Everything have to become normal. If it not, try restarting your system too.
I hope its helpful to you
Sep 07, 2009 | HP Photosmart D5160 InkJet Printer
HP Business Inkjet 1200 Lights flashing
Check the paper sensor has not come loose. Lift the lid, it is on the right hand side of the rollers with the red and blue wire. Press down lightly to make sure is hasn't come loose.
If not, reset the printer:
While the printer is on, press and hold the configuratuion button and press resume (paper feed) button 3 times.
Wait 20 second and press the power button.
Disconnect the power and wait 20 seconds.
Connect the power and switch the printer on.
Feb 24, 2009 | HP Inkjet 1200dn Printer
Hp deskjet 5552 how to reset?
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults. Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
Dec 02, 2008 | HP DeskJet 5550 InkJet Printer
Hp officejet g85 all in one
- try to unplug the power cord of the printer
- do the semi full reset
- press and hold the # and 6 keys
- and while holding the 2 buttons replug the power cord of the printer.
- do not release the two buttons yet
- wait for the printer to starts up
- if it turn off, release the two buttons
- then it will appear the smei-NVM reset
note: this can only be done once.
Jul 24, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Inkjet 1100d Printer Logo
158 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
