Question about Zebra Office Equipment & Supplies
Printer in error state
Green light is on. Installed new drivers. Computer sees printer. However printer says it is in error state when attempting to print
SOURCE: canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Posted on Mar 12, 2008
SOURCE: Printer won't print on my MacBook
Mine won't print from PC. checked everythong, re-installed drivers, got new ones... nothing, ...yes even formated the pc. but nothing.. unless i connect it to my canon s5 cam.... then the &"¤?& thing works....
Posted on Apr 18, 2008
SOURCE: My printer won't print from the computer command; it will print fax or copy a paper.
MY PRINTER WONT PRINT FROM THE COMPUTER. IT WILL COPY A PAPER, BUT NOTHING FROM THE COMPUTER COMMAND.
Posted on Nov 11, 2008
gwbm
  • 353 Answers
SOURCE: printer showing error
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. This is quite straightforward once you know what to do.
If you decide to have a go at replacing the ink pads yourself, post a new comment, and I will provide further help.
Posted on Feb 27, 2009
SOURCE: HP Deskjet 3500 series, my printer keeps telling
Hi
HP Deskjet 3500 serie --
There could be a Software issue or hardware issue --
1) To check the software issue
Print a Test Page -- from the computer
2) To check the hardware
Press the Power button to turn the product on.
Press and hold the Power button
Open and close the front cover four times.
Release the Power button. The self-test will print
and it it is printing the hardware is fine ...
3) Then you can check by changing the USB Cable connection
Posted on Jan 02, 2010
I printed a travel voucher from my HP F4185 .I tried to print an extra copy of the same voucher immediately .after which the green, red lights and E turned on. can"t use the printer anymore.
why not install the full driver set.
https://support.hp.com/us-en/drivers/selfservice/hp-deskjet-f4100-all-in-one-printer-series/3177560/model/3235293
with the full deal loaded.
you get errors from printer that are in English, tell you what is wrong.
why not try another computer connected to it to see if its
the printer
or the puter.
easy no?
btw no computer stated, at all, a MAC?
Apr 09, 2017 | HP Computers & Internet
My printer is an MP620B (Canon PIXMA). On attempting to print, error code 6C10 is displayed. I've visually inspected the far right interior of the printhead area and see no jams or obstructions. ...
Check if the drivers for the printer are installed and working properly on the computer. All the devices which are connected to the computer require a set of drivers to be installed on the computer. If the appropriate drivers are not installed on the computer then the device will not work properly. To check if the drivers are installed and working on the computer, right click on My computer and select Device manager. Highlight the installed printer. If there are any caution signs then follow the troubleshooting procedure. If troubleshooting does not help then try and update the drivers for the printer and see if it works. quote.gif
Sep 23, 2011 | Canon PIXMA MP620 All-In-One InkJet...
After installing printer & drivers printer is still showing an error. Error light is flashing and "sel" button will not remove flashing error. Printer has paper installed correctly, ribbon is...
After installing the printer and the software you must reboot the computer to register the hardware changes. After booting up open your "printers" from the Control Panel or Start "settings - printers".
Make sure that the printer is listed. If it is listed, right click on it and select "properties". Now the printer control panel will come up. Select - "Print test page". If the software and cables are installed correctly the printer will be listed and it will print the test page.
In the same way, with a right click on the printer you can select to make it your "Default" printer.
New operating systems will see the new hardware and offer to install it for you. If you say yes and OK the computer will do an internet search and it should find the correct drivers for your operating system. If it does not find the correct drivers for your operating system you may have to the companies web page and select support - downloads and find your correct driver.
Apr 13, 2011 | Citizen iDP-3550 Receipt Printer PC...
Attempt to scan, screen states
This error occurs because the HP scanner can not communicate with your computer and thus won't scan. In most cases this is simply because you don't have all of the necessary drivers installed.
  1. Insert the software CD into your CD ROM drive. The software installer should automatically start
  2. Install the software and restart your computer when prompted
  3. Try to Scan using the Scan To or Start Scan buttons on your printer
Jan 13, 2010 | Computers & Internet
Attempts to print on HP Deskjet F4280 shut down my programs
Sounds like the drivers are not installing properly. Are you installing through the CD or downloading the drivers from the HP website. Since a lot of the new drivers are no longer supporting XP you will need to download a scrubber utility and delete all of the pre installed drivers and attempt to reinstall through a manual installation of the drivers.
Apr 18, 2017 | HP DeskJet F4280 All In One Printer InkJet
Printer suddenly stopped printing
verify if you are printing with the correct paper size..... long is 8.5 by 13 and not 8.5 by 14.....
or
1. delete the installed driver
2. turn off the printer and let your computer detect the printer.... let it finish
3. restart your computer
Nov 09, 2008 | HP LaserJet 1020 Printer
Unable to print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Sep 07, 2008 | Lexmark X73 All-In-One InkJet Printer
Error code E5
hi dear
hi dear
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Mar 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
