Question about Cuisinart DGB-650 Grind & Brew 10-Cup Thermal
Mosture getting into coffe grinder in dgb-650
Getting wet inside the grinder
2 Suggested Answers
SOURCE: DGB-300
1-800-726-0190 Cuisinart toll free help line.
Wait till the coffee pot cools down. The plastic parts get hot and that is was causes it to stick. You can put the machine in the fridge about 20 minutes, to help it cool down faster.
Also, once the grinder is off.. spray vegetable oil Pam on the shaft that you put the grinder on. That helps to stop it from sticking.
I tried this and it works.
Posted on Aug 12, 2008
Why does it shut off with 2 cups of water left in reservoir?
sounds like you have a defective water sensor, needs to be replace or taken to be fixed
Dec 01, 2015 | Cuisinart Dgb-650 Series 10 Cups Coffee...
Brewed coffee overflowed on to warmer plate. Now water does not heat and flow and warmer plate does not heat up.
Unless it is an expensive brewer, get a new one. The brewer needs the bottom plate to heat in order for it to work at all. Should be imune getting wet though, but sounds like bad heating element.
Oct 11, 2013 | Cuisinart Model DGB-550 Coffeemaker...
DGB-600 won't stop beeping and is missind grinder
The grinder cover has a white pin as a part of the cover that acts as a go between for the plastic molded post on the cover and a contact switch in the unit. Without the cover in place the molded post is not long enough to reach the contact switch and "tell" the machine it's o.k. to brew. It will beep incesssantly and do nothing. Get a replacement cover, or jury rig something to act as a replacement for the grinder cover pin. You can manually push in the switch to get it to stop beeping, but it will spring back out as soon as you release it.
Dec 19, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
In my Saeco odeo go the the coffe that is discarded (pugs) is too wet and mushy.
make the coffe finer by adjusting the grinder this should help
Dec 04, 2009 | Saeco Odea Go
No cofee just beeping
Make sure every piece is in place. Usually the culprit behind the beeping is an out of place or damaged Grind Basket Lid - if it is in its proper place and you still get beeping even after unplugging the machine, then I would suspect that it is damaged - call Cuisinart for a replacement lid.
Jul 31, 2009 | Cuisinart Thermal DGB-600 Grinder
Need instructions to operate DGB-600BC
Thanks for the reply. Got rid of the coffee maker. Its a dud. No more information required.
Jun 18, 2009 | Cuisinart Thermal DGB-600 Grinder
DGB 500 Grinder
You may try opening the front cover first and removing the filter then after opening the top lid, remove the clear grinder cover and lift the grinder from the rear. After you get it out be sure to clean the motor drive shaft and the bottom of the grinder. then use a trace of vegetable oil to lubricate the motor shaft where is attaches to the grinder.
We are on our second coffee maker and it makes great coffee.
Jan 19, 2009 | Cuisinart DGB-500 Coffee Maker
Grinder hard (impossible) to remove
I had the same problem and used a little grease and it worked fine. Take out the bean cup and grease the male and female parts and it should work fine.
Jul 18, 2008 | Cuisinart Thermal DGB-600 Grinder
Grinder basket removal
Vinegar instead of WD40 - I am pretty sure a good portion of the DGB-600's have this problem, but that is hearsay.
May 31, 2008 | Cuisinart Thermal DGB-600 Grinder
Cuisinart DGB-650 Grind & Brew 10-Cup Thermal Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
