Question about Bunn NHB Coffee Maker
Clean my cafe before first time use. - Bunn NHB Coffee Maker
All lights are functioning but coffee is going directly into the dispenser. We tried to clean it but still same issue. Will it need a full repair or can we fix it from home
Try to put grinder (***** on top near cafe beans more to the right) on more rough. Choose less strong cafe and put cafe foam valve (if you have it) off (full left).
If problem persist, open the dispensing mechanism box, take all out, there is water dispensing pipe in the back (unscrew screws), take it out and clean it (the pipe should be hollow 5mm wide, it can take a day in vinegar to dissolve and/or water pressure and tiny *****-er to clean it).
Do the descaling&rinsing.
Try not to play around much as it might burn the pump.
Mar 18, 2016 | Saeco Odea Giro Espresso Machine & Coffee...
Clean lime scale from Ladylux cafe pullout
get a bottle of CLR and mix a batch then soak the head in it for awhile . Calcium Lime and Rust Remover
Oct 05, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
Cafe barista not frothing
the frother gradually gets milk buildup and loses suction- an air blast through the milk tube and up the spout (can get an aerosol at hardware store) will help as well as the cleaning cycle. Also I used a q tip to the top of the spout several times but just had the q tip top come off and may have blocked it completely
May 05, 2014 | Sunbeam Mr. Coffee Cafe Barista Espresso...
How do i clean my cafe before first time use.
Add about a half cup of white vinegar to the water an run it through
the maker about three times.After that use fresh water about three times. should be cleaned out .
Apr 15, 2014 | Bunn My Cafe MCP
BUNN MY CAFE BAD TAST WITH COFFE OR HOT COCO
Try really cleaning the basket that the water and coffee or cocao goes into. If you don't really clean it well, it will have the taste of the last thing brewed mixed in with the new brew. Coffee followed by coffee should not be a problem, but coffee followed by cocao will give the cocao a coffee taste, and visa versa.
Nov 21, 2013 | Bunn My Cafe MCU Universal 4-in-1 Single...
May cafe mate server have bug, the problems describe this way, if the timer start in cafe mate server it counts down it good, but if the remaining time is 1min, the client of the cafe mate server will...
Disable the task manager...
Because they will close the cafe mate in the process thats why it will disconnect to the server...
you disable/enable task manager in group policy tool.
May 06, 2009 | Microsoft Windows Server Standard 2003 for...
How to clear the flashing light indicating unit needs cleaning
I posted earlier with a similar question, I fixed it by doing this. First unplug the unit for at least 30 seconds to clear. Second, and you'll have to be quick, press the Program, Set and On buttons all at the same time. This should set back to default settings. Hope this helps.
Mar 24, 2009 | DeLonghi CAFE DUO Dual Drip Coffee Maker
Bunn NHB Coffee Maker Logo
13 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
zimcloud
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
