Question about DXG Technology DXG-308 Digital Camera
PC NOT ACCEPTING USB
PLEASE HELP ME!! the pc is not accepting my usb and i have already installed the cd like 3 times..but when i connected it simply says that the device was not found..when i insert the usb it comes out as new device found but then it says there was an error and it doesnt let me see the pictures..
  • 4 more comments
  • virycuba Nov 02, 2007
    hi benimur first of all thanks sooo much for you help..unfortunately i tried everything on the list and nothing works.. i seriously dont know what else to do..please help me!!
  • virycuba Nov 03, 2007
    sorry i forgot to tell you that.. # 6 was the only one i didnt do because i dont have a card reader..
    hi the problem with the picture is that they are stored in the camara's memory not in the memory card but yea i can see all the pictures... and well i tried using another usb but that usb is not the same as all the others..the camara's connection part for the usb is smaller than all the others so it only fits the camara...
  • NAOJ Jan 30, 2008
    WHEN I PLUG THE USB CABLE INTO THE COMPUTER THE CAMERA
    WILL NOT DO ANYTHING.
  • Anonymous Jan 31, 2008
    my pc doesnt accept the usb. not downloading pics nothing!
  • Danisaurus Dec 18, 2008
    Same here. My computer used to recognize it, even before I installed the CD. Now it doesn't & I don't have the CD.
    Brigadier General:
  • 6,966 Answers
On a similar post, my reply was....
A couple of things you can try:
1. Insert the Camera's USB cord to another USB port of your PC;
2. While disconnected from the PC, verify that the pictures are still inside the camera's memory;
3. Reset the camera (power on/off);
4. Check the camera's batteries;
5. Reboot your PC with the camera attached via the USB;
6. Remove the memory card from the camera and try uploading using a card reader;
7. Uninstall all instances of your USB in your PC's Device Manager, reboot and allow the PC to auto-detect  and auto-install necessary drivers; and
8. Verify that the software/drivers for your camera are installed correctly with no yellow or red markings.
Hope this be of some help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 02, 2007
  • Louie  Role
    Louie Role Nov 03, 2007
    Hi again,
    If you have tried # 6 of the previous posting using a memory card reader and still a no go:
    a. the memory card maybe at fault;
    b. the USB ports of your PC is ion question, verify that the USB ports are working by trying another USB device like a mouse, kb or webcam; and
    c. try using a USB Hub.
    Pls post back again results.
  • Louie  Role
    Verify that you can still see the pictures stored in your memory card using the camera viewer. If the camera displays the images, then the memory is OK. Alternately, you can format the memory using the camera (but of course that would mean deleting all the picture files).
    Do you have access to another USB cable that you can try?
Usb not connected
first check number of USB are using at a time if using more than one please remove other all USB connection and restart PC than connect phone if problem not solve than download latest zune setup and install. if problem not solve than manualy install driver from C:/Programfiles/zune
Aug 03, 2014 | Apple iPhone 5S
I got a behringer c-1u mic and I plugged my USB in the pc and it says no drivers are installed for this device and also the green light of the mic flashes soon as u connect it then dims out and stops...
Either you haven't yet installed the drivers (usually a CD that comes with - or can be downloaded from Behringer Website),
AND/OR your bios settings dis-allow plug-and-play USB devices. Restart your PC and enter Setup to check..
AND/OR your microphone is bad, have you had success with it on another PC?
AND/OR your USB Port is bad - are you plugging directly into the PC's USB, or a seperate multi-port Hub? I once had a multi-port USB Hub that burned up anything I plugged into it.. Took me about 3 devices to die before I simply changed the hub. Pwoblem solved..
Hope this helps...
May 03, 2012 | Computers & Internet
My nikia X3 model mobile is locked its security code is not accepting security code have dialled more than 3 times. I remove the battery & SIM card for over-night time but still that code is not...
dont worry, just follow the steps below:
note: u need to have a pc running xp
click to download NSS
http://www.b-phreaks.co.uk/NSSDownloadLanding.htm
TO RECOVER THE CODE
1. CONNECT UR FONE VIA USBCABLE IN PC MODE & INSTALL THE DRIVERS FOR UR CELL FONE PROVIDED WITH NOKIA PC SUITE.THEN EXIT PC SUITE
2. THEN INSTALL Nemesis Service Suite
3. SELECT USB VIRTUAL DRIVE during installation (in case of nokia6120c for nokia 5700 use diamond protection)
4. AFTER INSTALLATION OPEN IT, THEN CLicK ON SCAN BUTTON
5. AFTER THAT CLicK ON PHONE INFO, NOW CLicK ON SCAN
6. NOW CLicK ON PERMANENT MEMORY TAB given on right bottom of application
7. NOW CLicK ON READ, IT WILL READ THE PERMANENT MEMORY FILE & WRITE IT TO THE DISK
UR PM FILE WILL BE LOCATED IN THE PATH:
D:Program FilesNSSBackuppm?252*********.pm
open that PM file in NOTEPAD
8. now scroll uptil FIELD [308] and on the 5th RECORD ur security code is saved
like that
5=31303038350000000000 remove all the "3" digits and it will be like that
5= 10085 0000000000 now its 10085 thats it.UR LOCK CODE IS 10085
Mar 04, 2011 | Nokia X3 Cell Phone
I have the phone but will not accept USB. When you connect the USB it charges the battery.Can you help me somehow???
Please ensure that if you get a CD with phone manuel,Then install the software from the cd and reconnect with computer then you can connect computer,or you can change USB mode option from USB settings somethings like that in the menu.Thanks
Nov 05, 2010 | Samsung B3410 Cell Phone
How to intall it on windows vista
1 Insert the installation CD into the drive.
2 Welcome... will appear. Click Install.
3 Accept the License Agreement, and click Continue.
4 Install Additional Software will appear. Make your selection and click Continue.
5 Setting Up a New Printer? will appear. Select Yes, I am setting up this printer for the first time, and click Continue.
NOTE: If the printer has previously been configured on another machine, select No, my printer is already set up. I am installing it on another computer. Skip to Step 7 below.
7 Connect Your Printer appears. Connect the USB cable between the PC and printer. Select Connect USB Cable now, and click Continue.
8 Accept the prompt to Print a Sample Page, and click Continue. Image
9 Product Registration appears. Select whether or not to Register the product and take part in the Lexmark Connect Program. Click Continue.
10 When Thank You appears, click Finish.
Apr 14, 2009 | Office Equipment & Supplies
My Pc is not accepting USB and nt opening it
Possible Cases:
1. the BIOS is set to USB: Disabled
2. If you are logged-on to a network running Windows Server, then the admnistrator may have disabled USB access.
3. Virus that tweaks the USB ports to : Disabled
4. Dirty USB terminal.
5. Corrupted System (unlikely)
Hope this gives you an idea!
-levibit-
Mar 18, 2009 | Microsoft Computers & Internet
I am installing a Canon Pixma IP4600. Have plugged in power and USB connection and get alternate green and orange flashes. Followed instructions to disconnect and reconnect the power and usb but to no...
What operating system you have?
If your printer is a USB printer then do the following: First of all please remove the USB Cable from your PC completely. Restart your PC without connecting USB cable back to your PC. Now connect the USB Cable into the USB Jack from both ends and start your PC. Your PC will automatically accept this USB Hardware driver. After doing above steps please reboot your PC finally and Let me know the result, so I can further invastigate the problem.
Scott
Dec 02, 2008 | Office Equipment & Supplies
Wireless
Make sure the Vista driver for your wireless G USB adapter is installed. If not, you can download it from the manufacturer's website
Mar 27, 2008 | Belkin (F5D7230-4) Router (587009)
Toshiba SAatellite 100 Laptop
just update the motherboard driver cd again and try or else indivisually install the drivers from printer drivers
Dec 23, 2007 | Toshiba Satellite A100-S8111TD Notebook
DXG Technology DXG-308 Digital Camera Logo
111 people viewed this question
Top DXG Technology Cameras Experts
Jerry Greenberg
Jerry Greenberg
John Anderson
John Anderson
Are you a DXG Technology Camera Expert? Answer questions, earn points and help others
