Question about Kyocera FS Office Equipment & Supplies
When using the autofeed on my Kyocera FS-1035 copier, a dark line prints down the center of the page. What is causing this and how can I fix it?
What is causing the dark line down the center of my pages when I use the auto feed feature t make copies? How can I fix this problem?
SOURCE: kyocera printer problem
First I would recommend cleaning the printer. When you change the toner there is sheet of paper that comes with the toner cartridge that explains how to properly clean the printer. If you do not have that handy, there is a panel on the left hand side of the printer that you need to open. Once the panel is open you will see the waste toner bottle; leave it in place. Above and to the right of the waste toner bottle will be a green nob. Pull this green nob slowly in and out three or four times. This will clean the charging wire. Next underneath the green nob there should be a piece that looks like a rectangular box when you pull it out. I believe it is green as well. This is the charger grid. With each toner you should have gotten a small slate blue box with a plastic lid that has a piece of felt under the plastic lid. Remove the lid and this should slot in under the long, rectangular charger grid. Move this back and forth three or four times and than remove the slate blue box. Gently push the charger grid all the way back in and close the access panel.
If this does not fix your problem I would recommend getting service from wherever you purchased the printer as you may have damaged the drum.
Let me know if you have any further questions.
Henry
Posted on Aug 15, 2008
  • 40 Answers
SOURCE: Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
Posted on Jan 12, 2009
SOURCE: black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Posted on May 15, 2009
  • 62 Answers
SOURCE: KYOCERA FS C5030N PRINTS ONLY THE FIRST PAGE OF A
make sure you are using the KX PRINTER DRIVER first
if so..
tray changing the pdl format
in the printers and faxes area right click on your printer
right click go to properties.
click on device settings tab (you have this if you are using the KX driver)llhopefully you are
you will see a button (pdl) click on pdl
changed pdl to pcl5e
good luck
Posted on Feb 10, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: Black lines down on printed page
This is caused by dirt/debrise on the ADF (automatic document feeder) scanner glass. You need to open up the feeder where your originals are fed in and look for a strip of glass that runs from front to back. It is about an inch or so wide. You need to clean this glass to get rid of the lines. Some models have this glass just to the left of the large main glass, but in your case I beleive it is in the feeder itself.
Good Luck.
Posted on Apr 23, 2010
Kyocera FS-1020D starts print 1/2 way down page
Internal tests like Report Prints are printed correctly? Make sure the Paper Size Format is setted correctly both on PC and Printer. Try not to use a Generic or Universal Printer Driver. Try installing printer with an Windows Vista driver if the Win7 and 8 drivers won't solve the problem.
Jan 22, 2015 | Kyocera Office Equipment & Supplies
Dark lines fs 3900
The lines are more than likely caused by either the Drum, Developer or Fuser unit. I have found in many cases that if non genuine toner is being used this will give you poor quality images. You can try using genuine toner which may resolve your issue but you may have to run a few hundred prints to clear out the old toner before the image improves.
Apr 15, 2014 | Kyocera FS-3900DN Laser Printer
Dark line down middle of page, kyocera fs2020dn
check drum and blade, dv unit, and fuser for issues
Apr 05, 2013 | Kyocera FS-2020D Laser Printer
Whenever our Kyocera Fs-720 printer prints it leaves dark splotchy smudges all the way down the page, any suggestions?
Your printer probably is due for a maintenance clean, which can be done by a certified printer technician.
May 28, 2010 | Kyocera FS-720 Laser Printer
My Kyocera FS-C5030N has just started printing a red line on the right side of every page?
Try cleaning the magenta charge grid on the left side door of printer. But from my experience this is caused by the magenta developing unit wearing out or going bad. A kyocera dealer can help with this.
May 25, 2010 | Kyocera Mita FS-1020D Laser Printer
A black line is printing 6.5cm from the right side of the page
Clean the main charge, this is a step that is suppose to be done when replacing the toner but most people don't. The instructions to do this is in your users manual. If you dont have the manual go to www.gfbm.net to download one. Also make sure the cleaner is placed all the way back to the right when done or it will effect your prints.
Feb 16, 2010 | Kyocera Mita FS-1020D Laser Printer
My Kyocera FS-3830N isn't printing certain letters
Updating the driver will solve your problem. Go the Kyocera web page and look under legacy printers in the download area
Jan 21, 2009 | Kyocera FS-3830N Laser Printer
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
