Question about Kenwood Tk-250g Tk250 Vhf 160 Ch Narrow Band With Aa Battery Holder Mint 2
Charging what is the charging time for this and how often should it be charged? charging time
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 116 Answers
Normally working battery take 2-3 hrs if ur Battery and charger are working good.
Posted on Jul 11, 2016
How do I charge a moxie power scooter??
  • Turn the scooter's power switch to the OFF position.
  • Connect the charger's plug to the charging port on the scooter.
  • Plug the charger's power cable into a power outlet.
  • When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
  • Times recommended for your scooter.
  • Stop charging when the LED light is completely green.
  • Disconnect charger from the scooter, then from the power outlet.
  • Run your scooter before riding it to verify the battery charge.
Feb 02, 2016 | Health & Beauty
My can wont charge my battery and it wont rev about 2500 rpm in any gear. i have replaced cam sensor and crack sensor and put new timing belt and tensioner on?
My car won't charge my battery ? Check the alternator (charging system) . You put new cam & crank sensor an timing belt on for a charging system problem ? Or after you did this stuff ,now the charging system isn't charging the battery ?
Nov 10, 2015 | Cars & Trucks
How do I make sure the battery is charging correctly?
watch charging indicator when charging,,,u can check battery status after some time of charging
Mar 28, 2015 | Computers & Internet
Charge time
You can open the Windows and see the battery charging indicator on the right-bottom-corner. You can monitor the charging progress (every 10 minutes; the battery should get 1 more percent charging). Please make sure that there is a "charging" info when your mouse pointer is hovering on that icon. If the info is "not charging", then probably the battery is start failing or it is failed.
Dec 25, 2013 | Computers & Internet
Charging problem the red light and green light or both on when charging and the batteries don't seem to be charging
sounds like the batteries are dud, most chargers have 2 or 3 lights, red (max charging) Amber (battery nearing full charge) Green (fully charged and most will switch to a trickle charge) has the scooter been out of use for some time as scooter / wheelchair batteries must be kept charged, and only a short time of no use can destroy the batteries.
Sep 09, 2013 | Golden Technologies Companion II Travel...
Cant findwhere to charge ac
if it is a window unit you are trying to charge - chances are - there are no charging ports. Hardly any window units (that I know of) have charging ports when manufactured. The only time you'd find charging ports on one is if it had been 'charged' at some time in it's past history. Most window units run years and years without needing to be re-charged. Therefore - if you cannot find charging ports it means it's never been charged since being manufactured. Always 'be sure' a unit needs charging before opening the system.
Through the wall units (like in motels) sometimes - comes with charging ports - although not all the time.
Central units all have charging ports and they are located on the condenser (outside unit). Just follow your copper lines (one big one -usually insulated and a smaller one) - into the unit and the charging ports are not easy to miss.
hope this helps.
Jun 18, 2011 | Heating & Cooling
Problem in charging of dell inspiron 1525...on plugged in power it shows plugged in but not charging.. please give me the solution related to charging of the laptop..
If the charging LED is on but the battery is not charging then the battery may be worn out.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Dec 16, 2010 | Dell Inspiron 1525 Notebook
After charger is inserted , charging lights come on and battery indicater shows that is charging . After some time , an hour or so , a charging error message appears and says to stop charging . I purchased...
this problem was relating to your phones charging ic to solve this problem please change the charging IC WITH THE HELP OF A HARDWARE MECHANIC
Oct 22, 2010 | Cell Phones
Web cam installation, Charging & Flash problem.
This modelnot charging good because i charge hole day but no more charging was happens. Flash is not ok some time oprate sometime not.
Sep 05, 2008 | BenQ DC3400 Digital Camera
Kenwood Tk-250g Tk250 Vhf 160 Ch Narrow Band With Aa Battery Holder Mint 2 Logo
47 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
