Question about General Electric Dryers
GE GAS dryer DPGT750GCWW is not heating - General Electric Dryers
futureloginn
  • 734 Answers
SOURCE: ge gas dryer
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
SOURCE: gE GAS DRYER DCLR333ETOWW
need the location for the operating thermostat for model GE Dryer DCLR 333 ET OWW This is a Three wire thermostat that advances the timer in the auto mode heat
Posted on Jan 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: Gas dryer won't heat up
Check the flame sensor for continuity(if open no heat)
Check the ignitor for continuity(if open no heat)
Posted on Jun 08, 2009
ftw1952
  • 10319 Answers
SOURCE: G.E. gas dryer will not heat.
either the moister sensor is bad or the venting needs to be cleaned thoroughly. If clogged full of lint the sensor shuts down the heat until it is cleaned out
Posted on May 14, 2010
heatman101
  • 43501 Answers
SOURCE: i have a gas GE
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Dec 19, 2010
GE DBLR333GGWW gas dryer runs but no heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 19, 2011 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Ge profile gas dryer...i am not getting heat
heatman101';';
Jun 12, 2011 | GE Profile DPSB613G Gas Dryer
GE Adora, gas front loader, dryer will not heat.
heatman101
Jan 31, 2011 | GE Dryers
GE Gas Dryer not heating
heatman101
Jan 17, 2011 | GE DWSR405EBWW Electric Dryer
I have a gas GE dryer DPGT750GCWW ;- it only heats occasionally. Sometimes it will work all day, other times it will heat one load and won't heat up for the next load. The vent has been cleaned...
heatman101
Dec 18, 2010 | GE DBXR463GB Gas Dryer
My ge dryer wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
heatman101
May 30, 2010 | GE DBSR453GB Gas Dryer
Dryer not heating up
heatman101
May 24, 2010 | GE DPSE810GGWT Gas Dryer
GE Profile gas dryer tumbles but NO HEAT, not ignitor
heatman101
Apr 30, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Dryers Logo
57 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Harry Roberts
Level 1 Expert
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
