Question about Kyocera FS-1035 MFP/DP Monochrome Printer
I have a Kyocera FS-1035 and there is a dark line that prints down the center pf the pages when I use the auto feed feature only. What causes this and how can I correct it?
What is causing the line down the center of my pages when I use the auto-feed feature and how can I correct this?
3 Suggested Answers
  • 99 Answers
SOURCE: Kyocera FS-C5030N: Streaks blue & red vertical
Clean waste toner,Drum blade.
Posted on Dec 09, 2009
  • 241 Answers
SOURCE: Whenever our Kyocera Fs-720 printer prints it
Your printer probably is due for a maintenance clean, which can be done by a certified printer technician.
Posted on May 28, 2010
Kyocera FS-1020D starts print 1/2 way down page
Internal tests like Report Prints are printed correctly? Make sure the Paper Size Format is setted correctly both on PC and Printer. Try not to use a Generic or Universal Printer Driver. Try installing printer with an Windows Vista driver if the Win7 and 8 drivers won't solve the problem.
Jan 22, 2015 | Kyocera Office Equipment & Supplies
Dark lines fs 3900
The lines are more than likely caused by either the Drum, Developer or Fuser unit. I have found in many cases that if non genuine toner is being used this will give you poor quality images. You can try using genuine toner which may resolve your issue but you may have to run a few hundred prints to clear out the old toner before the image improves.
Apr 15, 2014 | Kyocera FS-3900DN Laser Printer
Dark line down middle of page, kyocera fs2020dn
check drum and blade, dv unit, and fuser for issues
Apr 05, 2013 | Kyocera FS-2020D Laser Printer
Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
Whenever our Kyocera Fs-720 printer prints it leaves dark splotchy smudges all the way down the page, any suggestions?
May 28, 2010 | Kyocera FS-720 Laser Printer
My Kyocera FS-C5030N has just started printing a red line on the right side of every page?
Try cleaning the magenta charge grid on the left side door of printer. But from my experience this is caused by the magenta developing unit wearing out or going bad. A kyocera dealer can help with this.
May 25, 2010 | Kyocera Mita FS-1020D Laser Printer
My Kyocera FS-3830N isn't printing certain letters
Updating the driver will solve your problem. Go the Kyocera web page and look under legacy printers in the download area
Jan 21, 2009 | Kyocera FS-3830N Laser Printer
Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
Nov 26, 2008 | Kyocera FS-C5030N Led Printer
Kyocera FS-1035 MFP/DP Monochrome Printer Logo
55 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
