Question about Xerox 8830 Copier
6180 states jam at reg roll cant see any jam
Our 6180 color copier states jam at reg roll open door a
2 Suggested Answers
SOURCE: I'm getting Jam at Reg
Had exactly the same problem... today actually.
Found the solution with another model's manual - I removed the paper from the top, but hadn't realised there was a jam in the paper tray. It was only when pulling it out completely that I found it as below...
Jam at Registration Roller
1. Remove Tray 2 completely.
2. Clear the jammed paper from the printer's
intake slot.
3. Re-insert Tray 2.
4. Open front door A.
5. Remove jammed paper if present.
6. Close front door A
Posted on Nov 25, 2010
My laserjet pro 400 color mpf m475dn printer is indicating " paper jam...open back door to clear jam," please describe how i will go about this process.
There is an access door in the back of the printer. Open the door and you should see jammed paper. If not then you have a faulty sensor or switch.
Mar 20, 2014 | HP LASERJET PRO 400 COLOR MFP M475DN
I'm getting Jam at Reg Roll on my Phaser 6180, and I think there may be a bit of paper in the paper path, but i can't see it. The machine says Open Door A, which I've done a few times, but it isn't...
intake slot.
Nov 23, 2010 | Xerox Phaser 6180N Laser Printer
My HP 6180 has very squeaky feed wheels. Is there
At the back of the printer is a door. Open door and put some very thin oil(firearm or sewing machine oil works well) either sides of the shaft that the black rollers are on.
Good luck
Jul 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
Everytime intry to print it keeps coming up as paper jam or open/close door. which there is no paper jam and door is closeed
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Jul 19, 2010 | Samsung CLX2160 Multifunction Color Laser...
Dell 3000cn paper jam open reg cover
Don't take risk about your equipments. consult a enjineer.
Aug 06, 2009 | Dell 3000cn Laser Printer
Reg door will not close
There is a flap inside the printer that guides the paper as it travels thru the printer. The flap has to be in a completely up position before the door can be closed. Problem is if you put the flap in the up position and then try to close the door the flap falls back down and blocks the door. You need to push the flap up and close the door quickly before it has time to fall back down.
Apr 01, 2009 | Dell 3100cn Laser Printer
X3550
What has happened to it? Did it have apaper jam? Let's try a simple reset first.
Turn off the printer and unplug it.
Open the paper jam door and gently roll the paper roller forward until it clicks. close the door.
Leave the printer unplugged for a few minutes then plug it in and turn it on and try it out.
If this does not solve your problem, you may need to reinstall your software. If you do not have it, let me know.
Aug 15, 2008 | Lexmark X3550 All-In-One Printer
Paper jam
I had the same problem kept getting an error something like Jam at Exit Door Open Door A. When I looked at the top of the where paper normally comes from and flipped it open I found a super crinkled piece of paper, which once removed cleared the jam.
May 03, 2008 | Xerox Phaser 6180N Laser Printer
21 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
