This actually a Jasco 15163 and according to www.harwareandtools.com it takes a Jasco 15602 tripper set. This tripper set can be found for online order at http://www.jascoproducts.com/products/pc/Replacement-Timer-Tripper-2-pack-p1089.htm#.U9Ov2bHG-f4
Timer brand and model number are not shown. Brand and model appear on inside of timer door.
Moving stationary pointer will not affect on-off operation of timer. The pointer is just reference for setting current time. Worn trippers can cause problem. Trippers are softer metal and designed to wear down so timer mechanism lasts for decades.
be sure that the trippers you are using are for this specific model if you purchased them seperately.
if they are for your model then make sure they are fully seated so that they are engaging the switch. if you are using trippers you have had a long time the remove one go to your local store where you can buy the low voltage power pack. they should have additional trippers to go with your model examine the new trippers to make sure yours look the same and are not worn or broken. if all appears good then you may have a problem with the switch that is engaged by the trippers and the unit may need to be replaced.
1) You posted under TORK Variable Cycling Timer 8601 This particular timer has built-in trippers. Sample manual for this type of timer describes tripper operation: http://waterheatertimer.org/pdf/8602INSTALLOP.pdf
2) You can see Tork trippers at following link. Page also shows Tork timers so you can identify your timer for certain. http://waterheatertimer.org/Tork-timers-and-manuals.html#Trippers
3) If you have a different brand timer, the particulars will show on inside of door.
4) Add a comment your brand and model number for more free help. I will find a source for your tripper, unless you have Paragon brand, in which case the trippers are no longer being made, and you may need a new timer.
5) Also take advantage of fixya phone service. For a price, fixya expert speaks with you over phone while you work on timer.
The two links above help you identify your timer model and identify the tripper. After identifying tripper number, you have to do a google search for that tripper number
So, if you need more help, please answer back and we'll find the right timer and pin
According to Intermatic literature, ML series Power Pack uses 107SB189
ON tripper, and 107SB192 OFF tripper. I have not ordered these trippers
and no image seems available.
