Question about TruTech PVS31170S1W 17 in. LCD Television
Fix coaxial cable connection
Snowey tv screen move cable it changes
2 Suggested Answers
maatmartin7
  • 1210 Answers
SOURCE: The coaxial cable connection into the TV loose
You do need to buy good coaxial cables at a reputable electronics store. You may sometimes use the slide in one with some luck. I prefer a high quality cable purchase at the cable or satellite tv office. The other thing is you may have too many connections going into the tv. You may a dvd or vcr player that is still on. Or the video game box is on etc. Or worse yet...the RF connector on the tv itself is loose and will require a new soldered one in its place...this will require a tv tech! Or the quik fix is to bypass the RF connector and use the RCA cables and Jacks. Hate to leave you with so many options...but most is covered now...good luck!
Posted on Dec 19, 2009
How do you get the picture in picture to work? What two sources can you use, a cable box and what?
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Let's say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected that's not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables; these can be found anywhere home theater equipment is sold. Then follow these steps.
1. Turn off both your cable box and television.
2. Take the coaxial cable that comes OUT from the wall and connects to the IN of your cable box and disconnect it.
3. Connect that cable to the IN on your coaxial splitter.
4. Connect your two extra coaxial cables to the OUTs on your coaxial splitter. We will call them cable 1 and Cable 2, just because.
5. Connect cable 1 directly to the DTV/TV input on your television.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by their Green, Red, Blue colors for video and Red and White cables for audio.)
7. Power on both the cable box and your television. Using the INPUT button on your VIZIO remote select the input connection where your cable box is located your cable box picture should come up on the Main screen.
8. Press the PIP button on your VIZIO remote to bring up the small box in the corner. Press the PIP input button until you select the TV input and you should be ready to go. You may need to perform a channel scan with your TV tuner to locate all available channels before you do this step. In order to understand better how to perform a channel scan please check under the F.A.Q.s in the discussion area of your particular model television.
In order to change channels in the small screen use the PIP CH - and + buttons located near the bottom of the remote. You can swap picture in the Main and Sub screens using the swap button and swap which screen will sound off its audio by using the AUDIO button. You might notice an X next to some of the selections in the INPUT and PIP INPUT screens when you have PIP activated. That means that input selection is unavailable and cannot be used. For example, if you have the input TV selected on your main screen then if you press the PIP INPUT button and bring up that input menu you will see X's next to the TV and AV selections. The X's mean that when you have TV on the main screen you won't be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them.
Sep 14, 2011 | Vizio VF550M 55 in. LCD HDTV
Really? cool... so I have a Panasonic HDTV 720p... just moved, no cable, but I have a TV antenna. Amplified indoor antenna. GE brand model 24700. I powered and connected the coaxial cable between the tv...
You need to go into on screen TV tuner/channel scanning setup page and change the signal source from CABLE to ANTENNA so it will scan again to pick up off the air signals. Please read the TV user manual for more details.
What is the model number of the TV?
May 15, 2011 | Televison & Video
Hi i have a sega megadrive 2 and have only just got it out, but now have a Bush digital TV and the Sega is on (power) but I can't either locate the channel or am confused on how it connects up to the Tv to...
I think those have the old style RF connectors.A coaxial cable with a grey or black box in the connection cable.Plug the coaxial cable from outside into the RF cable.Plug the RF cable into the TV coaxial input(regular cable input).On the back of the Sega,there should be a switch for CH3 or CH 4.Put the TV on the appropriate channel.If the signal looks bad,switch the selector on the Sega and change the TV channel.If you do not have the RF cable there is a place that still sells Sega accessories,but not Sega.They must have contracted with Sega.If you need the site let me know.
Aug 02, 2010 | Sega Megadrive Black Console
My insignia tv shows a NO DATA BASE error on screen. How do i fix this.
Try these tips:
Connecting your Cable box through Coaxial to the TV.
1- Turn on the TV and the Cable Box, secure all the coaxial connectors.
2- Press the "TV" button to be sure you are in the TV mode.
3- You need to set the TV in a specific channel for receiving the signal from the Cable Box, usually they are channel 3 or 4. Please press in the TV's remote those channels numbers and check if you are receiving signal about the Cable Box in any of them.
4- If you do, afterwards remember to continue using the Cable Box remote to change the channels instead of the TV one.
Connecting your Cable Box through RCA to the TV
1- Turn on the TV and the Cable Box, secure all the RCA wires.
3- Press the "Input" button to go to AV1 or AV2 depending where the Cable box is connected.
4- You should be receiving signal instantaneously after you have changed the Input and keep using the Cable Box remote for changing the channels.
Jun 21, 2010 | Insignia LCDTV26 26 in. Television
Muffled sound from rear speakers why watching TV
switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
Feb 12, 2009 | Onkyo TX-SR506 Receiver
PIP
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Lets say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected thats not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables, these can be found anywhere home theater equipment is sold. Then follow these steps.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by thier Green, Red, Blue colors for video and Red and White cables for audio.)
unavailable and can not be used. For example if you have the input TV
selected on your main screen. If you press the PIP INPUT button and
wont be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them. PIP like this is not possible using any dish or satellite broadcasting companies as all of their signals must go through their boxes to be decoded. The televisions internal tuner can not handle those signals and turn them into anything watchable. If you are using one of these companies contact them to see if they offer a set top box that does PIP on its own and doesn't need the televisions help to accomplish it.
Oct 11, 2008 | Vizio L37 Television
Coaxial to component
You may need an extra HD tuner for your TV. The only problem that you may have would be the original signal running through the coaxial cable. If it's just regular TV stations, the tuner should fix the problem.
May 22, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
PCM 2.0
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable box..my choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
Dec 19, 2007 | Audio Players & Recorders
RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
Yes, To change the input to video jacks, you must change the channel to 00.
Jun 25, 2006 | RCA F27645 27" TV
TruTech PVS31170S1W 17 in. LCD Television Logo
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
