Question about Maxtor 160GB OneTouch III Mini USB 2.0 External 160 GB Hard Drive
Mistakenly plugged maxtor one touch 2 into wrong power adapter
Unit is not showing any signs of live. Probably a burned fuse inside
the unit works with 12V power adapter and I plugged her into a 19V laptop adapter. are there any inexpensive solutions to it
    Problem Solver:
  • 6 Answers
Well Most Likely The Circuit Board Burnet Out Since Its 12V And When Plugged Into A 19V Supply It Will Burn Out Instantly Because It Over Charges The Circuits. So Its Not Possible To Repair Such Damage But You Can Take Out The Hard Drive And Plug IT Into A Desktop Computer And Use It At Home Or As An Online Hard Drive To Store Files
Posted on Jun 18, 2009
    President:
  • 1,185 Answers
You have probably cooked the voltage regulator circuit by hitting it with nearly twice the voltage it needs
The laptop supply may say 19v but that is when it is under the loading of a laptop.
Driving a HD it could run up to 23v which would make quite a few components in the HD go pop!
You can take the covers off and have a look as you have nothing to lose by doing so
If you find a fuse popped then replace it and try the unit with the correct supply and leave the cover off while you are testing it.
You may get lucky if they have gone for quick blow fuses
Ahmm i have a problem for my MAXTOR one touch 4 mini... when I plug in my External to the Unit it doesn't show to "My computer" but can be seen in safety remove and device manager... hm i...
You can try and restore your partition using Testdisk its free http://www.cgsecurity.org/wiki/TestDisk
If that does not work you probably have a damaged drive and will need data recovery. This guy is good and works off of donations. http://FreeDataRecovery.us
Jul 17, 2011 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
Our Wii console will not power on and there is a disk in it.
Follow the directions below to see if this helps. If not, you may need to contact Wii technical support for repairs.
power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
  1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip). acunplug.png
  2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
  3. We also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
  4. While you're waiting, check the AC Adapter for the following:
    • Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
  5. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked. If resetting the AC Adapter did not fix your power issues, please continue reading:
    • Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter (see above).
    • Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
    • Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
    • Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
    • Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
    • Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector). Click here for detailed instructions.
    • Once plugged in, check the power light on the Power button to see if the system is receiving power.
Click here to contact Wii support
Regards,
G33k
May 05, 2011 | Nintendo Wii Console
The power went out and now the wii wont turn back on?
HI. this is a power supply issue. Your unit is equipped with an external power supply unit. This box incorporates all the necessary AC current regulators, and transfer agents to run the Wii. There are ,also, some protection circuits as well. These are in place to protect the unit from surges are unstable AC spikes as well. There is a fuse that is located inside the power supply box. Simple unplug the power supply, and gain access to the fuse, by removing the outer cover of the power supply unit. there are a few screws,(on the bottom), that hold the top cover. remove the screws, and open the power supply unit. this will expose the fuse. Kindly, inspect the fuse. if it shows signs of trauma, and it is blown, simply replace the fuse.
Now, if the fuse shows no signs of trauma, or burn marks, this will confirm power supply circuit failure. This will require that you replace this damaged power supply unit asap.
Feb 08, 2011 | Nintendo Wii Console
MY Wii Console wont power up and everything is connected?
Now, if the fuse shows no signs of trauma, or burn marks, this will confirm power supply circuit failure. This will require that you replace this damaged power supply unit asap...
Jan 28, 2011 | Nintendo Wii Console
Wii wont power on
Now, if the fuse shows no signs of trauma, or burn marks, this will confirm power supply circuit failure. This will require that you replace this damaged power supply unit asap.>>
Dec 27, 2010 | Nintendo Wii Console
I applied the wrong ac adaptor to my external hardrive
My laptop adapter delivers 4A (ampères). Examine the HD adapter, and read all markings, looking for output intensity ( a number followed by a capital A). Do the same with you computer's adapter.
If output intensity delivered by the computer adapter is higher than the output intensity of the HD adapter, chances are you have blown out a fuse inside the HD enclosure (if you have a fuse)
In addition to voltage, intensity, there is the question of polarity of the adapter (positive inside ---C+ or positive outside ---+C. You can verify compatibilties of the adapters by comparing the C with a dot on both adapters.
Hope it helps sort things out a bit.
Sep 04, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
There is power to adapter but not in spacemaker unit
is there anything suspicious that you can see in the unit?like blown-out or busted? is the power switch on?
Jun 21, 2009 | GE SpaceMaker 05GP009 Television
Maxtor one touch 2 300gig wont switch on
Yes, this is a known Maxtor issue. They draw a lot of current, hence the 2 usb connectors. Devices that pull a lot of current need good connections.
Yes, the electronics inside the drive can go bad and they can be sent in for repair. Before doing that, though, try the following:
Make sure that the drive is plugged into usb ports that connect _directly_ to the motherboard (the ones one the back of the computer). Also, try to use usb 2.x ports instead of usb1.x
Try plugging the drive into another computer.
Aug 27, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
Burn circuits
The disk is probalby ok , it's probably just the power circuits for the USB/Firewire adapter that got fried,   if need be you could liberate the disk and use directly, or you could use a different Disk adapter to connect it via USB/Firewire again.
Oct 10, 2007 | Maxtor OneTouch II 300 GB Hard Drive
Maxtor 160GB OneTouch III Mini USB 2.0 External 160 GB Hard Drive Logo
434 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
