Question about Refrigerators
How to access evaporator fan motor ge bottom freezer
  • 5 Answers
SOURCE: ge profile refrigerator mod# tcx18paaarbb
drain tube is blocked .....you need to thaw it and after thawing clear drain tube all the way to condenser water tray in back
Posted on Apr 02, 2008
SOURCE: GE Refrigerator Eva. Fan Motor
which is the part number of the evaporator fan motor for refrigerator model GTS22KBP?
Posted on Nov 21, 2008
MNTECH
  • 1543 Answers
SOURCE: not cooling
Sometimes when the evaporator fan goes out, it takes part of the motherboard also. (part number WR55X10552, which also subs into a WR55X10656) If this is the case, I would not expect the refrig to be running either. (If your compressor still runs, check door switch.)
Posted on Dec 09, 2008
woodchuck789
  • 4070 Answers
SOURCE: GE Monogram Built-in refrig has blocked evaporator drain.
You should be able to see the drain under the coil. Part 804 on this diagram. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing.
Posted on Aug 26, 2009
  • 13 Answers
SOURCE: Evaporator Fan Motor noise is
Despite my urge to vent about GE refrigerators, I'll keep this short.
If you have a constant squealing noise from the evaporator fan in the freezer, there's a good chance the fan just has failing bearings, and replacing the evaporator fan might solve the problem.
But if the noise is intermittent; quiet sometimes but sometimes buzzing loudly, then my bet is there's nothing wrong with your evaporator fan. It's a problem with the design of GE fridges: They don't defrost completely. So ice builds up on the back freezer wall, etc., and on and around the evaporator fan. That's not a problem when the fan is in "low speed mode". But open the door, get the fridge warm, and the fan kicks into "high speed mode". That's when the noise will start, as the fan blades and assembly warps under speed to hit ice and start vibrating.
Acid test is this: While the noise is occurring, turn the fridge temp (not freezer) control up as high as you can without turning off the fridge. That will make the fan shift into low speed. If the noise stops, you got ice on the fan, my friend.
In that case, unplug the fridge, and get a hair dryer and blow warm air into and onto the evaporator fan area. Maybe gently whack the fan area with your hand a bit, to knock the ice off. Once you get all the ice off, turn it back on. If it runs on high, without any noise, the problem is fixed ... until the next set of high humidity days. I plan to post a video about this, once I get it edited to remove the expletives. ;-)
GE will sell you a "moisture kit" for $340, which may fix the problem, but only if your fridge is out of warranty.
If your fridge is still under warranty, GE will tell you there's nothing wrong and that maybe you just need ear plugs.
Posted on Aug 26, 2010
How do I access the evaporator fan on my GE mod. PDE18LZRACC fridge?
USUALLY BY REMOVING THE BACK FREEZER WALL U WILL HAVE ACCESS TO THE FAN, U MAY NEED TO REMOVE THE FREEZER BOTTOM PLATE AS WELL.
Mar 14, 2015 | GE Refrigerators
How do I access the evaporator fan in a GE apartment-size refrigerator model GTS12BBMARWW?
are u sure its where u say it is and not along the back side of the wall?
Feb 10, 2015 | GE Refrigerators
My GE Side by Side GSS25XSRSS keeps freezing up (bottom of each side only) with top portion of compartments much warmer (freezer side is too warm on top, all veggies are frozen on bottom of fridge side). ...
The evaporator fan is not working. You will have to open the front inside panels on the freezer side to get access to the fan, which is just below the ice maker. It may just require a little servicing, or the fan motor is bad or the controller at the back supplying electricity is bad.
Jan 10, 2011 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
Temperature control
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). The fan may spin, but it if goes too slowly, then it would blow enough cool air into the fridge, especially if it is opened quite frequently.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Top of freezer is fine but the bottom isn't as
Sounds like your evaporator fan is not doing its job. The purpose of this fan is to move cold air from the evaporator coil (behind the lining of the unit) to the rest of the freezer and to the refrigerator.
The fan should be behind an access plate at the top of the freezer compartment. If it is running, you should be able to hear it. If you don't hear it, open the access plate and look at it. If the fan is not turning, you will need to replace the fan motor.
Oct 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator forms and Ice dam which stops the evaporator fan from turning.
is it defrosting theres a glass tube which is the defroster bar,there known to have these fail
Jul 07, 2008 | GE GDS20SBS Stainless Steel Bottom Freezer...
Side by side cooling problems
replacing evaporator motor and mother board
Apr 02, 2008 | GE GSH25JFR Side by Side Refrigerator
Evap fan not working
you must remove baqck panel from bottom of freezer compartment, there you can access fan and other freezer components, check for open defrost thermostat as well.
Mar 30, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
