Question about Toshiba SD-V57HT System
I get error message when i turn it on
I have this Toshiba SD-V57HT System for almost two years. All of a sudden it started showing Error Message and is not ejecting DVD or VHS cassette from inside and sound system stopped working. Literally it went dead and shows ERROR in the display.
  • 8546 Answers
Get it.
Posted on Aug 27, 2011
0 characters
1 Points
Dvd keeps saying "format upsupported" for all movies
Get the free upgrade CD from BOSE and it will solve most of the problems when the program is loaded.
Jan 26, 2009 | Bose 3 2 1 GSX System
Roland SPD-S Flash card error
The card I have always been using is now also suddenly giving this message. I found an old SanDisk 16MB and a 1GB SanDisk that works perfectly in my Boss 864 and they also give the same message. Trying to go into formatting brings the message "no card!"
May 13, 2008 | Roland Spd-S Sampling Percussion Pad...
Technics DV290 system shows "change 1" error
i have a technics sh-dv290 and i need to know how to link the dvd to my tv???
Feb 26, 2008 | Technics SC-DV290 System
Sd 43ht toshiba
In most cases "PROTECTION" message appears when something is improperly connected to system. Try to disconnect everything, and reconnect it step by step.
Oct 11, 2007 | Toshiba SD-KT50 System
"Protection Error"
the DVD is blocked in PAL system, ¿ How I can the DVD in NTSC system ? the menu is blocked. thank
Sep 24, 2007 | Toshiba SD-43HTS System
Disc Read Error
This is the problem with your dvd player's lance so you need to repair it from your Toshiba DVD/VCR Home Theater System provider. and after replacing it u have to take care of it. do not use crashed disks . Use lance cleaner liquid to clean lance .
Aug 10, 2007 | Toshiba SD-V57HT System
Error with DAV-S500
Sony DAV-S500 error c-81: On the rear side of the DVD board connected to the DVDv drive is a power transistor Q002 that is shorted BASIS-EMITTER. The device is an Toshiba 2SA1213Y (PNP transistor 1$) Replace and your DVD works! good luck :) Foxi from Budapest, Hungary, Europe
Jun 11, 2007 | Sony DAV-S500 System
Error message upon powering on
Unplug it for 10 seconds then plug it in again
Apr 23, 2007 | JVC TH-A35 System
Toshiba SD-V57HT System Logo
20 people viewed this question
Top Toshiba Home Theater Systems Experts
Teet Bergmann
Electro Med Services...
David Payne
David Payne
Are you a Toshiba Home Theater System Expert? Answer questions, earn points and help others
