Question about HP e-PC 42 PC Desktop
Not powering up
I have hp e-pc 42, when i turn on the power switch i only hear a beeping sound and there is no light even the fan is not turning, i have checked the original power adaptor it has the right voltage as stated at its label, help
  • Joey Serrano Jun 19, 2009
    its an hp e-pc proprietary board, built in video audio and lan, i already tried reseating and cleaned the ram, cables and cpu as well, when i press the power button power led does not lit and the cpu fan is not turning after 5 seconds a continous beep is heaard, again help tnx a lot
  • reedm79 May 11, 2010
    Open the case and reseat the mem. and make sure the HDD Cable is snug.
    Problem Solver:
  • 6 Answers
Most power pc supplies either have a 12vdc and a 5vdc rail which have built in fuses (internally) also if any componets are not seated correctly in your pc the system will not boot . recently had similar problem due to loose graphics card
Posted on Jun 18, 2009
  • tazzie1313
    tazzie1313 Jun 19, 2009
    sounds like psu goosed the unless your fan packed up and cpu cooked
HP Pavilion not turning on, orange light and alarm sound.
Try a Hard reset!
1. Remove all connections from the computer including the power cable
2. Press and hold the power button for 20-30 seconds and then release
3. Only hook up the mouse, keyboard, monitor and power cable
4. Turn the computer
let me know what happens!
Oct 15, 2014 | HP Pavilion Computers & Internet
My hp envy 20 wont turn on
Need some more info:
Does the screen come on?
-What is on the screen?
--What happens when it fails?
Does a light come on the tower?
-Does a light come on in the power supply (where the computer plugs into the wall)?
Do you hear any beeping?
Do you hear any fans going?
Does the power supply fan (Where the computer plugs into the wall) try to start & fail?
-Or does it not try at all?
Apr 28, 2014 | HP Computers & Internet
Alarm beeps and orange light flashes when power is switched on.
If you unplug the power cord from the wall and the PSU, then flick the little red voltage switch on the back up and then back down again, plug it back in and it should work again
Feb 15, 2014 | HP Pavilion Computers & Internet
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
Nov 02, 2012 | HP Pavilion a1720n PC Desktop
The computer won't turn on
Try these steps if your computer won't turn on:
*You may or may not see a light on the back of your PC depending on the kind of power supply you have and the exact cause of the problem.(monitor light will likely be amber/yellow if your computer has stopped sending information to it)
*The power lights will stay on, you'll likely hear the fans inside your PC running, and you may or may not hear one or more beeps coming from the computer. If you hear beep sound, check your physical connections to the PC like RAM, Monitor, Cpu, Keyboard.
Jan 11, 2011 | Dell Dimension E310 PC Desktop
Monitor does not light up. Computer has power.
Did you hear a sound beeping. If you can hear a sound beeping it is a RAM problem. But if there is no sound beeping that is a processor problem. Remove the processor and clean make sure that the processor fan is spinning so that it will control the temperature of the CPU to avoid overheating.
Jul 31, 2010 | HP Pavilion DV7-1232nr Notebook
HP 42' Plasma Won't power on, does not power up..Won't turn on
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
Jan 08, 2009 | HP PL4260N 42 in. Plasma HDTV
Could a faulty fan cause my pc not to switch on
Normally the computer will still come on even if the fan is not there but then will sometime display cpu fan warning and then sometimes turn off depending on motherboard and so on but unless the fan wires are shorted out or something this is most likely not the case
It sounds like your power supply has gone bad
Do you hear any type of winning sound or like a discharge sound that is barely noticeable when you turn it on? You would probably almost have to put your ear right next to it to hear it or listen carefully when you press power because that sound is one of the capacitors in the power supply that has gone bad and the power supply would need to be replaced
Do you have another power supply you can use to see if it works with a different one?
Nov 25, 2008 | Intel Foxconn: Foxconn CPU Cooler For P4...
Hp Pavillion a420n blinking light
Hello!
Is the pc has blinking power in it. or do your hear any beeping sounds? but anyway you can do check your PC. unplug the pc and open the system. remove and clean the memory and insert it again. and fix all connection inside the pc maybe some cable lessen. after that test the pc. and then tell me what happen i will give you more solution in it. melnavz
Mar 25, 2008 | HP Pavilion a420n PC Desktop
HP e-PC 42 PC Desktop Logo
97 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
