Question about Drills
How to replace the brushes on a dewalt DW996 14.4 hammer drill
SOURCE: shake the drill to make it work
Sounds like the battery is not making a good connection inside the drill handle. Clean the contacts inside the handle where the battery plugs. Clean the contacts on the battery. If there are any springy tabs in either of these places, pry them up slightly to increase the pressure between the contacts.
Clean with wire brush, sandpaper, electrical contact cleaner.
If this doesn't work, get back to me and we'll go to the next step.
Charlie
Posted on May 09, 2009
rowdy45176
  • 2176 Answers
SOURCE: dewalt xrp 18 volt hammerdrill. Need gear schematics.
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will take you to a page where the schematics are.
Posted on May 24, 2009
  • 94 Answers
SOURCE: Dewalt 18V XRP Hammer drill, stops on torque in drillpositio
The brushes might need to be replaced. You can find them on Ebay and are easily to replace.
Posted on Aug 22, 2009
  • 5603 Answers
SOURCE: dewalt cordless drill dc988- drill motor works
Test the brushes by catching it in a stalled condition when you have it triggered, then rotate it slightly. If it takes off suspect the brushes or a dead segment on the comutator.
If it doesn't respond to this, then consider the VSR trigger... open it and test by bypassing it when in stalled condition...
Posted on Mar 20, 2010
puertobori
  • 7733 Answers
SOURCE: My DeWalt DWD520 Hammer Drill
Go to this LINK and find the part/diagram that can help you.
Please thumbs or post back,thanks
Posted on Nov 04, 2010
Dewalt DCH253 drill loses power
It's common for the brushes to pop out of place causing partial contact to the armature . If there not damaged you can simply slide the brush and holder back in place or replace if damaged. .another common issue is the leads going to the motor can become damaged . Most of the time you can clean the terminals and reattach them to the motor .if loose use pliers to carefully squeeze the terminals to the contacts on motor . .I hope that helps !
Sep 24, 2016 | Dewalt Hammer Drills: Hammer. 18-Volt...
Dewalt dw511 hammer drill won't hammer, only
The hammer inside the drill head are most likely damaged ans/or broken, it is likely the best thing to do is just replace the tool.
Feb 15, 2012 | Dewalt Drills
Drill has very little power/ even with full charge battery/ maybe brushes? thanks
It could be but more likely the motor itself is just worn out. I would replace the motor assembly as they do wear out on these models. Here is a link to the parts diagram.
http://servicenet.dewalt.com/Products/Detail/DC925KA
Jul 20, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
I have a dewalt 1/2 drill only used it once and it makes a knocking noise when using it. lost my receipt so can't return it, can you tell me what might be wrong with it . thanks
I'm pretty certain the brushes are loose and hitting against the armature. The brushes are held in place by a spring that looks like a ball point pen spring. The brushes are replaceable on that drill. I would take it to Lowe's or Home Depot and they should be able to provide brushes for it that you can replace yourself.
Mar 06, 2011 | Dewalt FactoryReconditioned DW235GR 12"...
DeWalt DC925 electronic brake repair?
first make sure brushes are not worn out and if not then replace the switch. the brake is contained in it to throw a short thru the motor when trigger released to stop drill. You can find a breakdown for this tool at Dewaltservicenet.com
Apr 04, 2010 | Dewalt 2 Dc925 18v ½ Hammer Drill /...
Dewalt cordless drill dc988- drill motor works intermitantly when trigger is pulled. Works a little better as it warms up. Im thinking vsr switch, brushes, or motor/armature. please help...
Mar 20, 2010 | Dewalt 18 Volt Dc988 Hammer Drill,dc825...
Aug 01, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Hi,drill started stopping and going and has now stopped altogether . dewalt dc988.18v
Replacing the brushes would be the first step. You can find them on E-Bay and is easy to replace.
Jun 27, 2009 | Dewalt 18 Volt Dc988 Hammer Drill,dc825...
Drills Logo
47 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
