Question about Locks & Locksmithing
Need to reset a tsa002 combination key lock - Locks & Locksmithing
4 Suggested Answers
jj505
  • 195 Answers
SOURCE: get the numbers master dial combination lock
Buy the identical lock if possiable and return as defective and they will reset. Otherwise odds or 1 in 999,000 differant combos. This is airport baggage security lock.
Please rate. Thanks
Posted on Mar 28, 2009
Obertelli
  • 3006 Answers
SOURCE: TSA locked our TSA002 lock on our samsonite bag
No. That's part of the whole purpose of TSA passkeys; they're held securely and only at ports. If it were easy for anyone else to get hold of them the locks which are TSA approved would become pointless.
You only have three options if you do not want to return to the airport:-
1. Get a locksmith;
2. Cut the lock off/drill it out;
3. If your lock is usually key operated (not a combination) then there will be a number next to the lock barrel (not the TSA number, that just tells the TSA which of their passkeys to use). A Samsonite dealer can order the correct key for you using the number and some even keep them in stock.
Posted on Oct 23, 2009
Keynan
  • 977 Answers
SOURCE: I have a Samsonite suitcase
Hi!
Take a look at the instructions here...
An interesting FYI is shown here:
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck & best regards,
Pelu.
Posted on Feb 20, 2011
Tsa002 change combination
Most combination luggage locks can be reset when they are open. The combination wheels can't be turned unless the lock is being reset. So either the wheels show the correct combination, or you will be able to turn them to a new combination. The lock that is "locked outside the hole" was either not relocked after inspection or it's in reset mode.
Jul 04, 2014 | Locks & Locksmithing
TSA002 - E110 Key
Ask the manufacturer.
May 09, 2014 | Luggage & Travel
How do I unlock a Master TSA002. I do not know the combination and I don't know what tools I need. I have important court papers in the safe and the spouse won't give me the combination. I know the...
Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Step 2 Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Step 3 Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Dec 18, 2017 | Master Lock 5400d: Portable Select Access...
I have a TSA002 lock which came with the luggage bag and having set the code accidentally, I've not been able to decode it. How can the problem be solved? I know there's a keyhole and a TSA 002 key will...
http://www.youtube.com/watch?v=OfchUwkEckI&feature=related
This link actually shows a man picking a TSA002 lock with a pair of standard tweazers. You can give that a try??
Sep 05, 2010 | Samsonite Tripod
I forgot my TSA002 lock combination. How to unlock it?
Hi, I watched the videos, but I still can't find a solution to open my luggage (Brand Antler) lock. I remember what is the passcode I set, somehow it just could be opened by using the same passcode.
Please help! thanks
http://nextkl.com
https://sewingasia.com
Apr 27, 2010 | Samsonite Tripod
TSA locked our TSA002 lock on our samsonite bag when they inspected it. We do not have a key. TSA said we needed to go back to the airport, but is there a way to get a key?
1. Get a locksmith;
Oct 23, 2009 | Samsonite Tripod
Get the numbers master dial combination lock
Please rate. Thanks
Feb 21, 2009 | Hardware & Accessories
I want to change my Master Lock combination
open the shackle twist 180 degrees...shut it as if u were closing it into the locking device..hold it down, put in what ur new combination is..pull the shackle up and shut it into locking device, and test it out.
Jan 25, 2009 | Master Lock 5400d: Portable Select Access...
Forgot my 3 digit number lock on my samsonite bag
lost 3 digit no on samsonite TSA002 lock
Sep 17, 2008 | Samsonite Tripod
Locks & Locksmithing Logo
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
