Question about Danby DDW1802W Built-in Dishwasher
How to fill salt container
Can't seem to get it apart. Doesn't lift out.
How can I solve the problem of the salt tank filling up with water?
This is not a problem. This is working as designed.
The salt tank gradually dissolves the salt in water to rejuvenate the water softener chemically. Once the salt is exhausted it needs replacing, but there is always water in the salt container.
Mar 19, 2015 | Dishwashers
Salt is blocked and not going down
u take dishwasher pump apart and cleaned from salt using water, it seems that the pump was jammed .
Oct 19, 2014 | Bosch Dishwashers
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
What do these lights mean there not going off
It appears that the water is going into the d/w the start timer is circulating and the water is being pumped out but the was cycle seems to be non existant :-(, there is a salt ligh on? Wat does this mean?
if the saly light is on it means you need to put salt in the sreservoir. There is a screw cap in the tank. Unscre this and fill the containers with DISHWASHER SALT. If the water is being pumped out during the wash the float in the base must have lifted. This means there is water in the base.This will ahve to be dried and an investigation carried ou to see where it came from Good Luck
Aug 09, 2010 | Bosch Dishwashers
We have a GE Model GXSF27E01 water softener. It
Try looking on the computer board for a battery back up. If it does have one, unplug that and then plug it back in and see if that will reset your control.
Jul 18, 2009 | House Brand Aqua-Pure AP102T Whole House...
Low salt light
try stirring the water in the salt container. however, as long as you renew the salt now and again, it doesn't matter
Jun 24, 2008 | Neff 24 in. S5453X1 Built-in Dishwasher
LG LD-2160 dishwasher
Get an aqua vac and suck out the water (with the dissolved detergent)from the salt container. Refill it with water and repeat the process couple of times. Fill the container with water and salt and it should be fine. Good luck !!
Jun 28, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
Danby DDW1802W Built-in Dishwasher Logo
19 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
