Question about Ricoh Aficio Office Equipment & Supplies
The copier says reset duplex unit correctly - Aficio Ricoh Office Equipment & Supplies
4 Suggested Answers
bowdo
  • 78 Answers
SOURCE: Lanier ld145 duplex error
The duplex is on the right hand side of the copier (external unit from the main print engine). You firstly need to check for a jam inside the unit, open the unit away from the copier and there will be a blue tab to access further beyond the black plates. Also make sure the unit is seated correctly and plugged in (Turn off unplug and plug back in, this will also reboot the machine). This is customer recoverable error so the reboot should fix it
Posted on Jan 03, 2009
SOURCE: I have a Lanier 5245. I am getting an error when
Examine the connectors of the duplex can be outside place some pin, also examine the sensor that is driven when the duplex is positioned can be dirty or out of position.
Posted on Oct 27, 2009
probeturbo94
SOURCE: Reset Duplex Unit Correctly on Ricoh 2232C
It happened to me on a 3228C and after 2 days diasembling the duplx unit on the left side of the machine, I found out that the problem was on a black tray inside the main unit, under the fusers, it was pulled out just about a quarter inch. All that needed to be done was to push it back in and serure it with screws.
Posted on Feb 29, 2012
Hp p3005x - how to replace formatter board
This is a known issue that cannot be addressed through menus. What you need is a PJL (print job language) file that programs the formatter activate the duplex function. Does your configuration page show the correct serial number and page counts? If not then likely the formatter you purchased was used. If you provide serial number, page count I can provide you with the correct PJL file that will restore your duplex function.
Sep 16, 2014 | HP LaserJet P3005x Printer
How do you set the Lanier LD035 duplex unit?
Metal tab on right side of copier is bent and correctly touching the duplex unit interlock switch. Open the duplexer and notice the metal tab stick out. Put back to a 90 degree angle.
Jul 30, 2014 | Lanier Office Equipment & Supplies
I have a gp 405 error 051 pleace help me
The error code E051 deals with the duplex jogger arms.... Mostly,it is saying that when you are duplexing the arms that move to keep the paper straight in the duplex unit are not moving correctly. It is the motor and saw tooth gears. It is located above the paper feed unit.... Good Luck
Sep 12, 2011 | Canon imageRUNNER 400S Copier
Your duplex is the big box on the right side of the machine push the back side shut against the machine and try again
May 08, 2009 | Lanier 5235 Printer
Duplex not recognised
You need to set the duplexer to installed. For Vista this would be done as follows: go to the Printers folder, Right Click on the 5550, Run as Administrator, Properties, (continue), Device Settings, Installable Options, Duplex unit (set to Installed), Apply, OK.
Once you have done this in Vista the duplexer will work but the back side may print upside down regardless of the settings. This can be corrected with a patch available here.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Mar 13, 2009 | HP DeskJet 5550 InkJet Printer
Minolta EP4320 - How to clear the "Cd" error code
A "CD" code means some thing is not closed correctly or attached correctly. It has been a very long time scine I worked on one, but I believe that when you added the duplex unit there is a bottom part of the duplex unit that is held on with two screws at the bottom and one shoulder screw at the top. From what I remember is that if the bottom part of the duplex unit is not flush withe copier stand and the top part of the duplex unit the joggers will not move and there is a sensor flag that get stuck in the bottom part of the duplex unit. Also, di you connect all of the connector for the unit that goes inside the copier it's self. You are dealing with a copier that is over 10 to 15 years old. Good Luck
Feb 16, 2009 | Minolta CF1501 Copier
Hi There,
The vertical box on the left side of the machine is not closed all the way. Open it, and close it again. It is directly on the left side of the main machine.
Scott K.
Jan 28, 2009 | Ricoh Aficio 1085 Laser Printer
Dec 26, 2008 | Lanier Office Equipment & Supplies
How do i resolve a sc520 on aficio 1085?
this is a duplex jogger error prob, open up your printer and ensure that the duplex assy is completely fastened onto the machine, any loosed connection can trigger an error, pull and push back the unit duplex once again to reset it, make sure this is sitting correctly and close the machine.
if not there is too much load on the jogger mechanism w/c make it so hard for the unit to initialize, then this will also occur check for any mechanical binding, if not then there is no choice but to change the jogger motor
cheers
Nov 30, 2008 | Ricoh Aficio 1085 Laser Printer
Duplexer problem
First, the machine always prints the first page first. Make sure you have the right driver (4 plus and not 4)and check the settings in the device settings of your printer driver on the pc. Also make sure the duplex unit is for the 4 plus and not the 4.
May 17, 2007 | HP LaserJet 4 plus Printer
14 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
