Question about Frigidaire ATF6000ES Front Load Washer
My kenmore front loader washer flashing all indicator lights and will not start
  • 822 Answers
The main board needs replacing
cheers
Posted on Mar 31, 2015
  • Frigidaire Master
  • 5,323 Answers
BLOWN FUSE?
3 Suggested Answers
  • 249 Answers
SOURCE: My washer is a whirlpool front loader. It keeps
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Posted on Jan 01, 2010
smitty5609
  • 243 Answers
SOURCE: Washer Starts, Stops by itself. Sometimes it works, sometimes it doesn't. Light flash on and off at random.
The flashing lights probably are a fault or error code. Sometimes you can diagnose the problem from them. The first thing I would do with the symptoms that you describe is check all the electrical for loose connections, Make sure all the plugs are fully seated in the control board as well as the components that they go to. Did you have an lightning storm lately. This could have blown the main control board. There is a method to diagnose each one of these that is listed in the service manual. You need to be fairly Savoy with electronics and ohm meters. Your service manual may be taped to the inside of your washer body, my whirlpool was.
Posted on Oct 21, 2011
Light flashing won start
Common error with front loaders is the door interlock. Make sure the door is positively closed. A gentle open hand push at the erea of the door lock often gets a machine started.
Regards
John
Jan 30, 2014 | Kenmore Elite 45986 Front Load Washer
WhirlpoolGB AWO 3751 Door firmly shut but red door locked indicator starts to flash and programme will not start.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Push Start button on our kenmore front loader washer model# 41744082400 and get error code 33.
F33 error code indicates Pump drive system error. Try running the unit empty, set to a cold/cold cycle. If this does not help, you will need to have the unit checked by a service technician.
thank You
Sep 10, 2010 | Kenmore Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Door locks, but will not fill up with water. Alarm sounds and lights flash once every minute or so
There is a rectangular magnet attached on the inside of the drawer for the detergent. Located on the right hand side near the front of the drawer. This magnet had come loose. Some glue and caulking worked well and the washer is working fine now. Meant to post this weeks ago.
May 12, 2009 | Kenmore Front Load Washer
Kenmore front loader Model 48102 will not start
Mar 14, 2009 | Kenmore Washing Machines
My kenmore front loader model 417 will not start
You have to replace the door lock(switch its all one unit) This will fix it.
Nov 16, 2008 | Kenmore 44102 Front Load Washer
My front loader stops at every cycle. Is there a simple solution to this?
Jan 22, 2008 | Kenmore 44832 Front Load Washer
Washer will not work
Possible drain fault, check filter. Regards Advisor
Jan 28, 2007 | Zanussi FJS1225W Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
