Question about LG Refrigerators
Can't remove lower light cover on lg c27921 - LG Refrigerators
How to remove SIM card from LG VX10000
Refer to these additional 4G SIM card do's and don'ts.
Ensure the device is powered off.
From the USB port (located on the bottom edge) gently lift and remove the battery cover.
From the notch in lower edge of the battery compartment, lift and remove the battery.
If necessary, remove the SD card.
Remove the SIM card.
Mar 27, 2018 | LG Cell Phones
How do I open the cover where the water supply is on a LG Fuzzy logic WF-T9250PP
You remove the screws that hold the lower panel in place to expose the water supply valve, float, and other parts.
Search Over 2 1 Million Appliance Parts
Sep 17, 2017 | LG Washing Machines
How do I remove front bumper cover?
To remove the front bumper cover you must first remove the turn lights in
the bumper. To do this remove the fog lights or the fog light covers by
removing the screw under the cover and remove the screw from the bottom that
holds the light in place. After doing this you will see a 12mm bolt behind
the light and one just to the inside of the lower grille. Remove all 4 of
these bolts(2 per side). Also remove the bolts /clips in the lower panel
under the bumper. The corners of the bumper near the fender actually slide
onto a stud that holds it in place. Just remove the bumper by pulling
forward. Sorry if this seems confusing but it is really pretty easy to do.
go to this link, once your on the acura site scrol down till you see the diagram
http://www.acura-legend.com/vbulletin/f4/bumper-cover-removal-128134/
Dec 21, 2010 | 1992 Acura Legend
I think something got passed the filter into the blower wheel (read some of the other questions and believe this is it; check filter light on and a burning smell was there when I tried to run it). I...
remove the top cover and control panel,then remove the front cover and the door and the blower wheel will be in the left lower corner in front behind the front panel
Oct 14, 2010 | LG DLE2514 Electric Dryer
No screen
First ensure that you have not tampered with the display of your phone from the menu.
If you did not tamper with the display menu, them the reason your cellphone is showing just a dim light is because there is a problem with the flex of your phone.
To fix this,
  1. Turn your phone over so the battery cover is facing you. Remove the battery cover and battery.
  2. Next remove the 2 rubber stoppers.
  3. Remove the 6 screws,
  4. Next remove the 2 rubber stoppers & screws above the main screen,
  5. Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet,
  6. Unclip the ribbon that is by the top right on the lower part of the phone, that is the flex of the phone,
  7. Replace it and reverse the process to reassemble the phone.
Take care
Jun 22, 2010 | LG KG220 Cellular Phone
LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Apr 09, 2010 | Refrigerators
Something is stuck in our LG front loader washing machine so the water wont empty in the spin cycle
There should be two screws under the front lower panel. Remove the two screws and remove the lower panel. You should be able to access the pump from here.
Inscrew the cover on the front of the pump and clean.
Dec 31, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
How do I get to the drain pump on my LG WM2032HW?
the drain pump is in the lower left corner, you can access by removing a little cover and remove two screws, then you can lay it on its side, to remove the hoses and the the electrical wires, check for restrictions inside the impeller before you change the pump, could be one of the problems.
Dec 23, 2009 | LG Washing Machines
ACCESS TO BULB
Looking at the television, on the lower right hand side is the ventilation opening. Remove the screws and then remove the cover. Inside the opening is the light bulb holding bracket that has a handle on it. Disconect the power wires (2) going to the bulb, remove the 3 screws holding the metal cover over the bulb and pull it out of opening. Then remove the screws holding the light bulb in place. Very simple and easy to replace.
Jan 14, 2009 | LG RU-44SZ61D 44" TV
Refrigerators Logo
15 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
