Question about Konica Minolta DiALTA Di200 Copier
Need Service message for Konica 7020
My church copier give a need service message and F-28-3
  • Konica Minolta Master
  • 6,696 Answers
High voltage circuit board is bad. Have you turn the macine off then back on (wait at least 10 second in between). to reset the machine and clear the code. if that code comes back after turning on and off. then a new circuit board is need. or have a service technician come out and look at the machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 25, 2009
    Problem Solver:
  • 9 Answers
There a short between the HV casing and the T/S wire as'y. Sometime by taking the HV casing out ( located on the right door) enfore the rubber insulator w/ black tape, that might fix your problem. If not you have to replace t/s asy and hv casing.
Posted on Jun 20, 2009
How to reset code 35-3 on photocopier konica 7020
DO THIS once because you are re-setting the FUSER it can catch on fire that will ruin a perfectly good day!!!!! Get a tech out to look at it.
Turn on the main and sub power switches.
Keep pressing the * button until the message
"Please enter service password." appears.
Input 9272 as the password and press the
[Start] key. (The password is fixed and cannot
be changed.)
[Mode Select Menu Screen]
Press 2 and 5 to select 25 mode. Then select soft switch. Set 3, then set 1 then change 1 to 0. to clear the code.
Jun 13, 2014 | Konica Minolta Konica 7020 W/fax Kit...
Konica 7020
Did you blow it up, probably not.
Click this link for the everything.
http://www.kmbs.konicaminolta.us/content/support/supporthome.html
  1. Choose the Category "Office Systems"
  2. Choose the model "7020"
  3. Click the error next to the Model dropdown box.
  4. Choose the 1876KB user manual called "User Manual for 7020, 7025, 7030 and 7035"
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
Service manual
Dear Friends need help to resite l detect value auto adjustment developer konica 7020 Thanks.
Kind Regards
Mir Afzal
Jul 18, 2013 | Toshiba E-Studio 3511 Color Copier
Konica 7020 error code f-26-2
Says that it is a PCL connector problem. Look at all of your connections and make sure they are ok.
Jun 24, 2010 | Office Equipment & Supplies
Error Code F-35-6 on Konica 7020
Please call the techie, he would definetely solve the problem, because their is a risk for the rollers to be burned out
Jun 16, 2009 | Sharp AR-C160 Color Copier
Paper jam
I strongly recommend a service tech. It sounds like you will need a PM kit,fuser claws and a few DFP rollers.
Mar 21, 2009 | Konica Minolta DiALTA Di200 Copier
KONICA 7020 GIVES ERROR MESSAGE F-35-1O WHAT IS WRONG
hi
error f 35 is fixing error,try to reset on 25 mode
Jan 08, 2009 | Toshiba E-Studio 3511 Color Copier
Konica 7020 f34-4
need to rest code 25 mode dip switch 3-1 should be 0
hope that help
let me know if you need more help with access
Sep 01, 2008 | Office Equipment & Supplies
Konica 7020 copier
35-9 is a low temperature error in the fuser.If the fuser has a problem it will not make a copy period.Sorry. Mrbonz
Jul 20, 2008 | Office Equipment & Supplies
Konica 7020 Printer
HI,
you need to reset the fuser latch as it has a fuser error code most likely needs new thermisters,
anyways give this a go, hold down 2 and 5 keys together and power on machine, this will put you into to a service mode call 25 mode, go to dip switch 3 and bit 1 and then next to bit 1 hit the key that says turn off,
turn machine off and back on should clear error code, if it doesnt you need new thermisters, even when you put in new thermisters you still need to clear this error in service mode
Regards
Konica Tech
Feb 15, 2008 | Office Equipment & Supplies
Konica Minolta DiALTA Di200 Copier Logo
177 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
