Question about Ruud UBHC Air Conditioner
Blower make noise when start for a few second and after work ok
    Genius:
  • Ruud Master
  • 1,363 Answers
Check squirrel cage on motor might be touching fan housing on start up.
Posted on Aug 12, 2015
2008 vw jetta makes noise from blower
OK. The noise you are hearing is the recirculation flap motor. It could be what is causing the condensation. Easy way to check in after the noise has stopped push the recirculation button on the AC controls to see if the noise happens. If the motor is bad and the flap isn't closing you could be getting moisture from the outside air. As far as the check engine light goes there is no relation. 2 completely different systems. The flap motor would probably run you a couple hundred of dollars. The check engine light could be anything.
Dec 14, 2013 | 2000 Volkswagen Beetle
When i turn on the blower on high its makes a nioce but its ok when on a lower speed
BLOWER IS GOING BAD REPLACE IT BUY ONE AT A JUNK YARD ITS VERY CHEAP : )
Feb 12, 2013 | 2007 Dodge Nitro R/T
My blower resistor is always fail, I install a new one it's work a few weeks and fail again, I install a new blower moter and a new blower resistor it's work a few weeks and the resistor fail. The...
you can get a new resistor and you have to start the blower at hi always to avoid over heating in the resistors and protect the thermal fuse, the second after you had started the blower you can select any speed.
Aug 21, 2011 | 1999 Plymouth Breeze
Screeching noise after water starts going in
Hi just read your posting.Now put the machine to a spin cycle and push start,Does the noise happen in this cycle? If the noise doesn't happen then try a cold water fill but turn the hot tap off first.If the noise still doesn't happen then try a hot water fill but turn the cold water off first. This noise sounds like one of your water valves is faulty.Please reply with additional information on the questions and I am sure we can rectify this fault.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
1997 Dodge Grand Caravan heater blower makes clicking noise
take out the blower motor
if the bearing is ok
use a vacuum cleaner to suck out the debris in the piping
Apr 28, 2017 | 1997 Dodge Grand Caravan
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Mar 11, 2009 | Carrier Heating & Cooling
When i start the engine make noise for few seconds
It sounds like you need to check and replace your engine oil and oil filter. This will happen when it is cold and dirty and it takes time to get to the oil ports in the engine. I hope this helps. Don't forget to rate my answer. Thanks.
Feb 21, 2009 | 2004 Saab 9-3
Scrubbing noise while dryer is runing
you need to replace felt on drum
Feb 19, 2009 | Maytag MDE9316 Dryer
Goodman GMP075 Problem
check the mfds of the capacitor.if its ok you need a blower motor.
Aug 09, 2008 | Heating & Cooling
Ruud UBHC Air Conditioner Logo
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
