Question about Hardware & Accessories
Vigoro water timer 196 036 water timer programming
I am having trouble programming it. The ''how often'' button jumps from days to hours. What do I enter to get it to turn on once a day and twice a day?
Every x days vs every x hrs. (once a day or every 12 hours)
Posted on Jun 29, 2009
At daylight savings time the timer jumped 2 hours forward. How to I set it back an hour without going thru whole set up process?
Expert cannot see the timer you are talking about without model number or photograph
-With modern timers, usually the product manual shows how to change DST with push of button or by pushing two buttons simultaneously.
-If the DST was not set correctly when first programmed, then probably you have to reprogram.
-Normally, with modern timers, the on-off programs stay in memory if you re-enter current time of day and set DST.
-Most modern timers have battery back-up or capacitor back-up
-Only if you press reset button are the memories wiped clear
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/How-to-troubleshoot-timers.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 18, 2015 | Hardware & Accessories
I need instructions to the Vigoro- Duo Deluxe water timer 9 volt battery operated # on back is 0708..# on fromt top left is 225-379 Purchased at Home Depot I has5 to 6 cycles that can be programmed. I...
The vigoro duo delux might be same as Melnor 3100
Open following links:
http://www.melnor.com/instructions.php
http://www.melnor.com/instructions/3100_InstructionSheet.pdf
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 02, 2011 | Hardware & Accessories
Vigoro 196-036 water timer manual -- need instructions on how to set timer for the Vigoor 196-036
Here is theinstruction:1. Install the battery2.Use left attor to decrease and right arrow to increase numbers < > to set current time to nearest hour at the time, noting AM and PM3. Repeat above instructions to set "start time: to desired time for day to begin watering4. Use left and right arro <> buttons to set "how often" (watering frequency) to select an hour/day increment (8 hours=3 times per day, 2 days=every other day).5. Use left and right buttons < > to set "how long" (watering duration) to select a min. or hr increment.6Activate the watering program by pressing the Program on/off buttin: a horizontal bar will be displayed to signify the program is on. Press the program on/off again to disable the programTo avoid accidentally changing the current program, the arrow button will be "locked out" or inaccessible if "program on" is selected.To create a new program, press Program on/off if necessary to disable current program.
Jun 12, 2011 | Hardware & Accessories
I have the Vigoro (196-036)/Melnor water timer. I bought it last year to replace a different model. I replaced the battery and set the program this year, but the program isn't working. I can use it...
At the
Bottom right there is a button to turn the program on and off. Make sure you have it on. I think a black little
Bar shows if it is on.
May 07, 2011 | Garden
I have a IIIWoods timer #59203WV and have trouble programming it to turn on and off exterior lights. Thanks for your response.
Manual:
http://waterheatertimer.org/pdf/Woods-59203.pdf
59203 plug-in timer: your outdoor lights have to plug into side of timer.
If you want a timer to replace outdoor light switch: buy in-wall timer Aube T1032 or Lowes sells Utilitec 0192773.
http://waterheatertimer.org/Programmable.html#Aube
Add a comment for more help with in-wall.
Here are instructions for 59203 plug-in timer:
Plug in the timer until battery is charged.
Unplug timer so you can program easily.
Press R reset button with paper clip to clear.
Set the time of day:
Press and hold clock button
Press hour button until current hour shows
Press minute button until current minute shows
Press day button until current day shows.
Release clock button
Program review:
Write out ON-off schedule showing hours minutes and days
For example: timer turns ON 6:00 pm all days of week.
Timer turns OFF 1:00 am all days of week.
First step: Set program1 ON > hour, minute, and day.
Next step: Set program1 OFF > hour, minute, and day
If needed, go to next step: Set program2 ON > hour, minute, and day
Next: Set program2 OFF > hour, minute, and day
How to program timer for ON at 6:00 pm and OFF at 1:00 am all days of week:
Step 1: Press PROGRAM button until display shows 1 ON (this is program1 ON)
Press hour button until 6 pm shows
Press minute button until :00 shows
Press day button until all days of week show (MO TU WE TH FR SA SU)
Step 2: Press PROGRAM button until display shows 1 OFF (this is program1 OFF)
Press hour button until 1 am shows
If you want to set another program, you will repeat same steps for program2
Press PROGRAM button until display shows 2 ON
If you are done programming, press clock button
Press ON/AUTO/OFF button until AUTO displays
Nov 13, 2010 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
I have 2 Vigoro 196-036 watering timers. Why does water come out of the three holes near the battery compartment on one of them?
It comes out of the holes because the water goes in the holes. That might sound dumb but Vigoro designed these only to be in dry conditions, such as attached to the water line. I used them for sprinklers, but the water poured into the timer so bad it shorted it out in a week. I did find a vigoro timer with no holes and a sealed unit, and they work great. But I can't find them anymore.
Aug 25, 2010 | Hardware & Accessories
Regarding the Vigoro Electronic Water Timer, Model 196 036: How do I program the timer to water every day, in the early a.m., then in the evening? Is the greatest hourly spread per day 12 hrs.? In...
I think you almost have it right, you can program how many hours apart.
4=6 x per day
6=4 x per day
8=3 x per day
12= 2 x per day
24=1 x per day
Then you set how long you want it to be on, but that can't exceed your hour setting. I believe these are the same timers as Melnor. You can go to their web site for manuals. http://www.melnor.com/instructions.php. If you really want exact timing, I'd get a quality electric timer, and then buy a electric valve such as you'd use for a sprinkler system.
Jul 13, 2010 | Garden
My vigoro water timer i bought at home depot will not stay on manual off/om or on its program. I have installed the new 9 volt battery correctly since i can program ok but it shuts off in a short time...
I have a Vigoro 271-687 in which has worked well except when i change the batteries it wont reset and will not work do you have any solutions to this problem i really like this product just dont understand the prob
Jul 01, 2009 | Garden
Vigoro water timer problems
I also had this problem and found that the water pressure was too high. I turned the water spicket down one a a half turns (yours may vary) and now it's working fine.
May 05, 2009 | Garden
Hardware & Accessories Logo
4,946 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
