Question about Garden
Sp470 blue smoke - Garden
Blue smoke 96 honda prelude
Blue some is burning oil. Check your PCV valve 1st, but if this is bad, your idle would be high. If it smokes when 1st starting only, the valve guides and/or seals are bad. If it smokes while driving, the rings are worn out.
May 05, 2014 | Honda Prelude Cars & Trucks
My 1999 cadillac is smokeing really bad blue smoke but not looseing oil or anti freeze
blue smoke comes from too much oil in engine.thats can be the rings round the piston. the top ring is for leaving a film from oil so the piston
can run smoothly up and down.when its worn out you get to much oil
and see blue smoke.second possibility is valve setting,these tiny,
rubbers can worn out too and leave blue smoke behind.
Jul 27, 2012 | 1999 Cadillac DeVille
I have a mountfield sp470 petrol self proppelled lawn mower. the engine is briggs& stratton but i dont know the engine model. i need this as the cylinder head gasket has gone and needs replacing.
Hi. The SP470 has a 4 HP Briggs and Stratton engine.
The part number should be 687171 and you can look here:
http://www.worldofmowers.ltd.uk/Products/ProductList.aspx?search=Head+gasket+&type=3&searchBtton.x=20&searchBtton.y=10
Take a good look at the valve end of the head gasket. From the pictures on the page you should be able to see which one of the 4 head gaskets on the page is yours.
If you have yellow pages you can look up lawn mower repair. Or small engine repair shops. All of them should have this commonly used headgasket in stock. Just find one close to you or.. use the link above.
Here is yet another link for the head gaskets but you have to scroll way way down the page or page search for 698717 or 272171.
http://www.briggsbits.co.uk/acatalog/Horizontal_crankshaft_2-7_HP_Sidevalve_Engines.html
Thanks for choosing FixYa.
Kelly
Sep 12, 2010 | Garden
Service manual
No such thing exists - but you can get an Operator's Manual for the engine if it's a Briggs & Stratton, direct fron the Briggs web site.
Sep 16, 2009 | Garden
No spark on my sp470 any ideas please. its got a new plug
ITs pointless so .you need to check and see if coil is grounded from you off switch replace coil and clean flywheel and it will run
Aug 21, 2009 | Garden
Lancia Thema 16v turbo series 2 is smoking with blue smoke
if the blue smoke is constant then it is valve seals and guides, if it is only after depressing the throttle then it is the rings
Jul 28, 2009 | 2007 Lancia Beta
Puffs blue smoke
Blue smoke is caused by engine oil entering the cylinder area and being burned along with the fuel air mixture. As with the white smoke, just a small drop of oil leaking into the cylinder can produce blue smoke out the tailpipe. Blue smoke is more likely in older or higher mileage vehicles than newer cars with fewer miles.
This could mean a cracked head or bad gasket....It costly
Dec 08, 2008 | 1997 Suzuki Sidekick
Blue smoke coming from exhaust
blue smoke out of 1.8 turbo its allways bad oil seal inside turbo.need new turbo or rebuild OEM. with 24 years experience working with vw never seen single headhasket go bad on 1.8 turbo engines.blue smoke its 100% turbo every time
Jul 17, 2008 | 1999 Volkswagen Passat
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
