Question about Zanussi Dishwashers
Dishwasher tablet door not opening - Zanussi Dishwashers
  • 236 Answers
SOURCE: Dishwasher tablet not releasing
sounds like the dispenser solenoid is faulty you will need to replace the whole unit, this involves removing the door panel.
Posted on Jun 11, 2007
rylee_smith
  • 8619 Answers
SOURCE: Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Posted on Feb 22, 2009
landsend
  • 1066 Answers
SOURCE: dishwasher opens tablet door but tablet is not used
are these self desolving tablets with covered in plastic film?  If they are use another brand of tablet, or turn the heat up on your water heater as it is set too low.
Had the same problem
Posted on Mar 15, 2009
VtToolMan
  • 704 Answers
SOURCE: Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Posted on Jul 31, 2009
  • 37 Answers
SOURCE: Detergent tablet not dissolving.
sometimes the dispenser doors are not designed for tablets, and they don't let enough water in to dissolve them....next time you wash; put the tablet in one of the silverware compartments....should do the trick. and leave the dispenser door for liquid detergents only.
if this is helpful please click the correct button. thanks
Posted on Jan 22, 2010
Model number FDB4050LHB1, is very loud when operating and does not dispense cleaning tablets or liquid, cycles through but does not clean, and cleaning tablet or liquid still in door, tablet door will not...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Nov 28, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Jul 31, 2009 | Electrolux Dishwashers
Soap won't dissolve in dishwasher
I had the same problem and my wife fived it by unsticking a valve to the left side of machine in front lets water in she poped it open and dried soapm came out restarted and now works fine.
Jul 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
ZANUSSI 695 Integrated Dishwasher
Most dishwashers work best when the food is rinsed off the dishes before they are put in the dishwasher. Also, run the hot water into the sink until it is hot and then turn on the dishwasher. good luck.
Jan 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Soap doew not disolve
first start the washer listen for it to fill then open the door and see how much water is in it let me know but hold my rating till we finish
Jan 31, 2008 | GE 24 in. GSD3210Z Built-in Dishwasher
Dishwasher tablets
Is your dispenser opening at the correct time ? You should hear it when it opens. If it does not open replace the part inside of the door panel called a wax motor. This part opens the dispenser.
Dec 09, 2007 | Tappan 18 in. MDR251RE Built-in Dishwasher
Bosch dishwasher
your not supposed to be using tablets in the bosch dishwasher. the ball on the tablet gets the lid stuck. the sticker on the door recomending tablet is advertisment. your owners manual says to use powder only
Nov 18, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Jun 08, 2007 | Indesit 24 in. DE73 Evolution...
Tablet door dosn't open during cycle
It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
Jul 02, 2006 | Hoover 24 in. DT999 Free-Standing...
The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Another option is just to place the detergent tablet on washer's bottom before starting its cycle. Good luck !
May 26, 2006 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dishwashers Logo
19 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
