ERROR A3200 KYOCERA KM 1635 SHOWING ERROR A3200
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
jyackle5
  • 8197 Answers
SOURCE: I HAVE A PHOTOCOPIER MACHINE KYOCERA KM 1635, DOES
According to the manual you can not scan with it. Sorry. Also here is the manual if you need it.
http://www.kyoceramita.eu/dlc/eu/documentation/usermanual/km-1635-2035-og-uk.-downloadcenteritem-Single-File.downloadcenteritem.tmp/KM-1635-2035-OG-UK.pdf
Good luck and please rate
Posted on Sep 16, 2009
Testimonial: "it was100% p"
  • 165 Answers
SOURCE: How to reset maintance call on kyocera km-1635?
10871087 then 251 then hash key then set it to 0 or cancel to reset the counter
Posted on Apr 05, 2010
  • 36 Answers
SOURCE: MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Posted on Apr 09, 2010
SOURCE: My Kyocera Mita KM-KM 1635 displays error call c6000
press 1087 1087 than insert 163 than press start 4 time
Posted on Nov 21, 2011
Kyocera Mita Km 1635 showing error code A0610 solution
my dear your heater problem rest codes in program 10871087
after press 163 and codes rest
Apr 29, 2015 | Kyocera Office Equipment & Supplies
Km 1635 c-3 error what is a problem
Kyocera mita km 1635-installed new drum but printing blank papers
Sep 06, 2013 | Office Equipment & Supplies
Error code A3200 for kyocera km 1620
how to repair kyocera km 1620, showing error message "A3" "200"
Mar 31, 2013 | Office Equipment & Supplies
Kyocera mita error codes of KM 1500
Hello sir; The error code you display A3200 is not available in our menual, we do have C3200 , if that's correct, it means exposure lamp burn out ( not on), replace it, or thermos fuse out.
May 13, 2009 | Kyocera KM-1505 Copier
189 people viewed this question
k24674
jasbo
jasbo
