Water runs out as fast as it fills- just started happening
  • 6,784 Answers
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Posted on Jun 19, 2009
Water level switch on kenmore 500 washer
Probably a defective fill valve or level switch but could be a controller fault
May 31, 2018 | Kenmore Washing Machines
My whirlpool just started leaking from the bottom of machine onto the floor. This happens when the machine is OFF and no clothes in machine. Is it a switch
The drain hose has to be higher than the water level at its highest point. IF there is water coming into the machine when it is not running then you may have a bad water inlet valve. They develop leaks like any faucet or valve. It could be some other things too, like the voltage to the valves is not completely cutting off. There is also some water that stays in those machines because it cannot all be pumped out. What is the model number?
Oct 29, 2017 | Washing Machines
My machine start to fill with water and about half way full the water starts running out juswt as fast as it is going in
Check the drain and see if the drain valve or pump is open due to clogging of dirt. If so back flush the drain and reset the unit , drain pump.
Jun 11, 2012 | GE Clothes Washer Model Select Connector -...
Not getting enough water
Hi just read your posting.Now what water temp are you using for you wash cycle?Is it cold , warm or hot?Problem could be your cold water valve not opening enough or your motor controller.If you selected a COLD wash how fast does your cold water come in to the machine?Please reply with additional information on the questions and I can help you rectify this fault.Looking forward to your reply.
Jul 27, 2010 | Fisher and Paykel IWL12 Top Load Washer
Washer doesn't fill with water and begin wash cycle. I can hear it instantly draining out rather than fill, and has ran my well dry. We replaced the water pump a month ago, and it washed a few loads of...
Sounds like siphoning. This can happen if your drain pipe is too low and you run the drain hose right into it, or if there isn't any kind of air gap between the drain hose and pipe. Usually it shows up when trying to fill for the rinse cycle - it drains as fast as it fills. Or it might not fill at all. Order a "siphon break kit". They're cheap and easy to install
May 26, 2010 | Roper RAS6233KQ Top Load Washer
Washer will not hold water
You need to check drain hose, the drain hose needs to be above the tub. If it isn't the water will just drain out when you fill
Jan 12, 2010 | Washing Machines
Maytag top load washer water runs but doesn't fill.
Drain is to low. You will have to raise the drain hose above the top of the washer. Whats happening is the water is siphoning out as fast as it goes in.
Please rate this solution
Sep 02, 2009 | Washing Machines
Cold water wash very slow fill up
Hi, you have a blockage on the cold side of your inlet valve, take the hose off on cold side of the valve and inspect screen..You may find some debris. If no debris is found you may have a bad valve..your going to need to replace it...if you have any questions please don't hesitate to contact
Jun 23, 2009 | Washing Machines
Kenmore washing machine will not fill with water.
Jun 01, 2009 | Kenmore Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
