Question about Masonry Tools
How to remove drum on cement mixer 606230E - Masonry Tools
2 Suggested Answers
terryskelly
  • 5168 Answers
SOURCE: I have bottom part of older portable cement mixer trying to find name/model number so we can get the top part. How can I submit photos to see if anyone recognizes it? Pot to be removed.
Google images has a way to search for similar images on the internet. If you put your picture on the internet, for example, on your own Facebook or other page, there is a way to search.
However, you have placed your question in the Food Mixers category. Is it a portable cement mixer or something else, perhaps spelled differently?
Posted on Feb 24, 2018
Feb 24, 2018 | Food Mixers
Cement Mixer won't run or start
Is there power in the wall socket. Check with a lamp?
Does the motor get warm when plugged in for a while?
Does the motor have a starting capacitor? Look for a metal tube on the side an inch or so in diameter. Those are AC electrolytic capacitors that are a common failure item.
Apr 18, 2016 | Food Mixers
Drive belt for kino electric cement mixer
try the place you bought it .I have a different brand and there is no belt . direct drive thru a gearhead
Jul 14, 2015 | Masonry Tools
Drive belt for kinzo electric cement mixer
Driver belt for kino electric cement mixer
May 13, 2015 | Masonry Tools
MY MINI MIX CEMENT MIXER IS BROKE DRUM WILL NOT TURN WHEN LOADED
This is the food mixer forum, not much cement gets mixed in the kitchen around here, too much danger of a flying rolling pin.
Sep 06, 2014 | Food Mixers
Why are the mixer barrells on cement trucks always turning?
The are always turning if there is wet cement inside. Because wet cement settles really quickly so if it isn't turning it will dry on the bottom of the mixer.
Jan 10, 2013 | Masonry Tools
Lescha Hobby 125 S electric mixer requires new drum main bearing
I had a similar problem on a Lescha Hobby Mix 120 SF. (Sounds similar to yours) The failure seems to have been caused by corrosion of the ball bearings. If you get water into the rear bearing housing when it is operating, and then store the mixer with the opening in the drum downwards, the water collects around one of the bearings. The bearings are a standard size ball bearing with a 62mm outside dia, 30mm bore and 16mm wide. I bought the sealed version from a local bearing supplier (or look one up on the Internet). The original ones fitted are unsealed, which is part of the problem. I also bought two new bearing retaining external circlips for a 30mm shaft. I had a paint round inside the housing with hammerite, and drilled some 10mm dia drain holes around the outside of the housing near the bolting flange. I also store the mixer with the drum horizontal now.
May 27, 2011 | Gazillion Cement Mixer
Masonry Tools Logo
94 people viewed this question
Top Masonry Tools Experts
Tom Chichester
Are you a Masonry Tool Expert? Answer questions, earn points and help others
