Question about Brother IntelliFAX 560 Plain Paper Fax
Retrieve fax after power outage
Had a power outage and I know I had at least 2 faxes . after power was restored the faxes did not come out.
checkitright
  • 1362 Answers
SOURCE: fax in memory
here is the manual
http://www.retrevo.com/s/brother+1840++fax+manual
Posted on Jan 22, 2008
Logjam
  • 159 Answers
SOURCE: Receiving Faxes
You will have to ask yourself the question "What has changed?" If you changed nothing, then something else has that is beyond your control. Now, you have to decide whether you are using a single telephone line for faxes and telephone, or whether you have "distinctive ring" also called "smart ring" by some companies. It is not a smart thing to use both. You can print a list of settings to see what the machine is set to do. Now if you want to use distinctive ring, set the ring pattern to the one you have chosen with the tel company. If you have chosen a double ring, and you have set your panasonic telephone to receive on 4 rings, then it will count all the rings and pick up after only 2 sequences. To see if this is the problem just remove the telephone base station from the system and then try to receive a fax.
Posted on Jun 09, 2008
  • 12 Answers
SOURCE: confirmation that a fax went through
How many faxes did you send in the last 20 days. Most Fax Machines only keep 30 - 35 in the journal report if less than that what model do you have and I should be able to help
Posted on Aug 13, 2008
leroyal
  • 2120 Answers
SOURCE: brother fax-575 has no power
No, sorry.
Posted on Nov 13, 2008
e-ware
  • 776 Answers
SOURCE: I want to retrieve just the last 2 or 3 faxes from
You can get the information required through the manual at:
http://www.brother-usa.com/Support/Default.aspx?WT.cg_n=Support
Posted on Sep 11, 2009
Power outage
its gone when themachine is turned off from the power outage, have them resend it
Apr 15, 2014 | Brother IntelliFAX 560 Plain Paper Fax
How do i retrieve a fax from fax memory?
The reason why this happened?
1- out of papers
2- Out of ink
3- power on jam
try to solve all this issues without switching off the machine.
Mar 08, 2014 | Canon Pixma MX452
Fax memory full
To gain extra memory, you can turn off Fax Storage OR Print fax messages in memory (See Setting Fax Storage, page 48.) OR Expand the machines memory.
Retrieve or Erase a Fax
Press 9 6
then to
Retrieve all faxes Press 2, then enter the number of remote fax machine and then press # #. After
the beep, hang up and wait.
Erase all fax messages Press 3. If the data stored in the memory has not been printed before, it will be printed first and then erased.
Setting Fax Storage
If you set Fax Storage to ON, you will be able to retrieve fax messages from another location, using Fax Forwarding or Remote Retrieval functions. The screen will indicate when you have a fax stored
in memory.
1 Press Menu, 2, 5, 2.
2 Press left arrow or right arrow to select ON (or OFF), and press Set when the screen displays your selection.
3 Press Stop/Exit.
If there are faxes in memory when you turn the Fax Storage OFF, the screen prompts you to erase any faxes in memory.
If you press 1, all fax data is erased and Fax Storage is turned OFF. If the fax data in memory has not been printed before, it will be printed first, and then erased. If you press 2, data is not erased, and Fax Storage remains ON.
Feb 07, 2012 | Brother FAX-8360P Plain Paper Laser
Panasonic cordless phone no dial tone changed batteries -no help other functions work--menu light doesn't lite when phone rings
electricity went out for 10 hrs
decided to switch phones around----not phone problem
phone ok in all phone outlets in wall
it was plugged into fax machine--maybe electric power outage hurt fax phone connection for phone line
fax works fine, just can't work as did before with phone line into fax
will call brother #775 monday
all was plugged into power surge
maybe have to adjust something on fax or buy new one because of power outage????????????????
Nov 22, 2009 | Panasonic Lands Phones
Fax connection
To send a fax, you will have to configure the settings. here are the steps you can follow;
Remote Fax Options;
You can only use one remote fax option at a time:
Fax Forwarding—OR—Paging—OR—Fax Storage—OR—PC FAX Receive—OR—Off.
You can change your selection at any time (Menu/Set, 2, 5, 1).
Setting up Fax Forwarding
When you select Fax Forward, your MFC stores the received fax in the memory. The MFC will then dial the fax number you’ve programmed and forwards the fax message.
  1. Press "Menu/Set, 2, 5, 1".
  2. Press ▲ or ▼ to select "Fax Forward". Press "Menu/Set". The LCD will ask you to enter the fax number to which faxes will be forwarded.
  3. Enter the forwarding number (up to 20 digits). Press "Menu/Set".
  4. Press ▲ or ▼ to select "Backup Print:On or Backup Print:Off". Press "Menu/Set".
If you select "Backup Print:On", the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is forwarded.
5. Press "Stop/Exit".
Programming your pager number When Paging is selected, your MFC dials the pager number you’ve
programmed, and then dials your Personal Identification Number (PIN). This activates your pager so you will know that you have a fax
message in the memory.
1. Press Menu/Set, 2, 5, 1.
2. Press ▲ or ▼ to select Paging.
3 . Enter your pager phone number
followed by # # (up to 20 digits). Press Menu/Set.
Do not include the area code if it is the same as that of your MFC. For example, press 1 8 0 0 5 5 5 1 2 3 4 # #.
4. If your pager needs a PIN, enter the PIN, press #, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press 1 2 3 4 5 # Redial/Pause 1 8 0 0 5 5 5
1 2 1 2 # #) —OR— If you do not need a PIN, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press Redial/Pause 1 8 0 0 5 5 5 1 2 1 2 # #)
5. Press Stop/Exit.
■ You cannot change a Paging number or PIN remotely.
■ If you have set Paging, a backup copy of the received fax will
automatically be printed at the MFC.
Setting Fax Storage
If you select Fax Storage, your MFC stores the received fax in the
memory. You will be able to retrieve fax messages from another
location using the Remote Retrieval commands.
1 Press Menu/Set, 2, 5, 1.
2 Press ▲ or ▼ to select
Fax Storage.
Press Menu/Set.
3 Press Stop/Exit.
Setting PC Fax Receive
If you select PC Fax Receive, your MFC will temporarily store your
received fax messages in its memory, and then automatically send
the faxes to the PC. You can then use your PC to view and store
these faxes.
PC Fax Receive.
Press Menu/Set.
3 Press ▲ or ▼ to select
Backup Print:On or
Backup Print:Off.
Press Menu/Set.
4 Press Stop/Exit.
If you have turned on Fax Storage, a backup copy will
  • Before you can set up PC Fax Receive you must install the
MFL-Pro Suite software on your PC, make sure your PC is connected and turned on. (For details, see Using Brother PC-FAX software on page 5-1 in Software User’s Guide on
the CD-ROM.)
  • If you select Backup Print:On, the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is sent to the PC.
■ If you get an error message and the MFC cannot print the faxes in memory, you can use this setting to transfer your faxes to your PC.
Turning off Remote Fax Options If you set the Remote Fax Options to Off and there are faxes in your MFC’s memory, the LCD will give you two options.
  • If you press 1, all unprinted faxes will be printed and erased
before the setting turns off. If a backup copy has already been
printed it will not be printed again.
  • If you press 2, the memory will not be erased and the setting will be unchanged.
Setting your Remote Access Code
The remote access code lets you access the Remote Retrieval features when you are away from your MFC. Before you use the remote access and retrieval features, you have to set up your own code. The default code is inactive code (--- ).
  1. Press Menu/Set, 2, 5, 2.
  2. Enter a three-digit code using numbers 0-9 or . Press Menu/Set. (The preset ‘ ’ cannot be changed.)
  3. Press Stop/Exit. Do not use the same code which is set in your Fax Receive Code ( 51) or Telephone Answer Code (#51). You can change your code at any time by entering a new one.
  4. If you want to make your code inactive, press Stop/Exit in Step 2 to restore the inactive setting (--- *).
May 05, 2009 | Brother MFC 7420 All-In-One Laser Printer
HOW DO I SEND A FAX ON THE BROTHER MFC-5440CN? LOST MY MANUAL
Remote Fax Options;
5. Press Stop/Exit.
Setting Fax Storage
Fax Storage.
Press Menu/Set.
3 Press Stop/Exit.
these faxes.
PC Fax Receive.
Press Menu/Set.
Backup Print:On or
Backup Print:Off.
Press Menu/Set.
4 Press Stop/Exit.
the CD-ROM.)
Apr 22, 2009 | Office Equipment & Supplies
Retrieving old fax transmissions
Usually the journal only holds the last 50 sends / receptions.
Feb 02, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Panafax UF-6000 can send but not receive
Yes, especially if they were active.
Do they show Code 21?
Factory reset them.
Unplug the power cord from the back of the machine
While holding down the ENERGY SAVER key, plug in the power cord.
Scroll down to SHIPMENT SET
press SET
press 2
wait for machine to reboot
Oct 16, 2008 | Panasonic PANAFAX UF-6000 Fax
Brother IntelliFAX 560 Plain Paper Fax Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
