Question about LG CU500 Cellular Phone
Music I have an lg cu 500 and I want to put some of my music on it from my computer...i have a memory card in it that works just fine but every time i try to lik click and drag to my memory card and then put it back in my phone it says that it cant read my file form itunes and zune...what software do i use?
  • skynsea809 Dec 24, 2008
    i kind of have the same problem
    when to copy and paste music into my memory card, it won't let me
    all of my music is from Zune software so what can i do?!?
Must be mp3 format
Posted on Nov 06, 2007
1. Purchase a Micro SD card
2. Make sure you have a memory card reader for your pc if not buy one.
3. Plug in your memory card and memory card reader to the pc.
4. Drag music onto your card.
5. Put memory card back in your phone!
Sep 18, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Cannot put music onto phone
#1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from or
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Apr 24, 2010 | LG KG300 Cellular Phone
Micro SD card wont work
Try Formating the 1gig chip in 'Fat' not Fat32, then put it back in phone,, should work then.
Also the phone aparently will only recocnize up to 2Gig (But U need a Firmware upgrade)
Hope That helps!
May 23, 2009 | Palm Treo 750 Smartphone
Whenever i insert the memory card in my lg kp 500 phone and press music, it restarts. what should i do to access my music?
This occurs when you have connected the Handset to the PC and removed it before disconnecting it from the PC safely and while there is an ongoing data transfer. Connect to PC again, delete all music files, again transfer music files from PC to external memory, safely disconnect and then try hearing music. It will work. Try it out
Apr 29, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
1gig SanDisk micro card is not reconized by LG 500 mobile phone
delete that file off of the memory card and try it again.
If no go then I would try it on her hand set and back up the data to a comptuer using the usb cable on either handset ( which ever the memory card works fine on ) and then wipe the memory card transfer it to your handset and do what you need to do and you should be able to load the data from your handset on to it once its been wiped.
If you want to put the data back on you should be able to use the usb cable - assuming you got a usb cable of some description.
Otherwise if you have bluetooth you could enable bluetooth on both your handsets and transfer the data assuming you have enough storage space on the other handset.
If not let me know how you get on or what problems you come across and I will try and help further.
Apr 11, 2009 | SanDisk 1GB microSD Memory Card
Downloading music to phone
if im correct you have to make a folder called music on the memory card so that the phone knows were to look for it, same with photos its pictures
Feb 16, 2009 | LG CU500 Cellular Phone
Cell phone freezes when i try to use my music from my memory card.
this happens sometimes. sometimes you just have to let it be frozen for a while, then it'll start working again
Oct 27, 2008 | LG CHOCOLATE VX8500 Cellular Phone
LG Chocolate micro SD card
You need to format inside the phone. Go to Settings-Memory-Card Memory-Options-Format card. Do that, put it back in your computer, and put music (MP3's) into the My_Music folder.
Aug 14, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Lg cu500
1 GB max for this phone and you must us a sandisk brand micro sd card it is not compatible with any-other card. Yes, it will work for a little while but you with have problems eventually. I replaced mine with a sandisk micro sd card and I have had no more issues.
Mar 16, 2008 | LG CU500 Cellular Phone
type 277634# * # (no spaces)
click port setting
click mass storage
click mass storage remove
go back to main screen and check again for memory
if this doesnt work,take out memory card and try without the memory card.
Nov 01, 2007 | LG CU500 Cellular Phone
LG CU500 Cellular Phone Logo
35 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
