Question about Empire DV-35 Heater
Emits odor when starting
When I turn up the heater in the morning while heating up it emits a toxic odor that lasts for about 30 minutes.
What should I do?
Turn it off and Do not use! Return it to the place of purchase to be inspected.
Nov 30, 2015 | DeLonghi Safeheat 24" Tower Ceramic Heater
Heater runs and heats, but it "coughs" while running and emits a flame along the cone.
because it is gas , i would advise getting an accredited gas fitter to find the fault
it could be a blockage in the jet , regulator but it needs a professional to look at it
Nov 23, 2015 | Heating & Cooling
Strong gas odor only when oven is in operation?
If you're talking about the acrid smell immediately after starting the oven, that's aldehyde gas, a byproduct of cold gas combustion where the flame contacts the cold metal oven surfaces. That smell should disappear within the first minute or two, and it's entirely normal for a gas oven. If you're talking instead about the smell of fuel gas, then your burner may need to be adjusted; it may be running much too "rich".
Aug 23, 2014 | Electrolux Ovens
Emits high pitched whistling after unit runs for 30 minutes
Sounds to me like the bearings are going bad in the motor. The hotter it gets the grease breaks down and the squealing starts.
Jun 30, 2017 | Haier CPRB07XC7 Portable Air Conditioner
Dryer emits odor
nothing can be done
Apr 11, 2012 | Amana Dryers
It emits a metallic burning odor.
The trouble began in 2003 when Consumer Reports magazine published a report claiming the expensive air cleaners don't clean air. The magazine later claimed its tests showed that Sharper Image's Ionic Breeze Quadra Silent Air Purifier and four other units also release potentially unhealthy levels of ozone.
Read more: http://www.consumeraffairs.com/news04/2008/02/sharper_image.html#ixzz0VATFAuRq
Oct 27, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Glo Warm Self Venting Heater Model FB3B Emits strong odor
The propane may have a higher sulfur content; however, the odor may go away soon. It is probably caused by the dust and oxidation (micro-rust) that attached itself to every part of the heater while in storage, even though it was "sealed".
Sep 29, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Where is cabin ac filter located
If the air conditioner emits a foul odor into the cabin it is probably the drain tube on the evaporator core is clogged. What happens is the clog causes mildew to start growing and then it blows the stink right into the car. And to answer your question the cabin air filter location all depends on the year make and model of the car.
Jun 09, 2009 | 1999 Ford Windstar
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
I have a Frigidaire Gallery model plhs267za. The refrigator doesn't freeze or emits cold air. When I turne it off for a coule of days it works again. The technician says compressor is ok as weel as fan...
Freezer coil is plugging up with frost, Your problem is defrost timer or heater related. If it is the timer you can located the timer and rotate the Clutch screw for the timer, turn it very slowly Clockwise until you hear one click. The compressor will shut off and the defrost heaters will turn on. Waite about 25-30 minutes and if the refrigerator does not restart (Normal time would be 18-22 minutes) rotate the screw again clockwise small amount and it will start cooling. Observe the drain pan for defrost water. If the refrigerator restarted (18-22 minutes) and no water is in the drain pan you problem is defrost heaters. If after the 25-30 minutes the refrigerator did not restart on its own and water is in the drain pan your problem is the defrost timer.
May 02, 2008 | Refrigerators
Empire DV-35 Heater Logo
26 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
rudyjoe
Level 1 Expert
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
