Question about Fujitsu fi-5530C Scanner
SA01032E getting an SA01032E error "scanning was stopped, check scanner."
Wen i try to scan my photoes an error message pops up...... SnanGear error code 2,140,2. It says printer is in use or an error has occured. Check status. Scanner driver will be closed
Stop your printer running while you are scanning photos.
It defines error because your printer and scanner running simultaneously.
Eject your printer while scanning.
Jan 07, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Cannon MP530 scanner won't scan document it shows error code
hello ! reinstall the machine fax and scanner program cd's may be the installation was not completed or is the machine having issues .
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Scanner stopped working
check the windows firewall or antivirus.may be blocking the scanner
Apr 29, 2009 | Office Equipment & Supplies
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
TWAIN Driver Error
If connected via USB, unplug cable and insert into another available port and error message should disappear.
Nov 14, 2008 | Fujitsu fi-5120C
SCAN STOPS MIDWAY
Are you getting an error/ red light on the scanner button when its on? when scanning from Paint ( File, then from scanners and cameras) does it freeze as well? or only when using epson scan? make sure cable is directly connected from the scanner to your computer, no hubs or anything.. keep me posted.
Have a nice day!!
Jun 12, 2008 | Epson Perfection 4990 Flatbed Scanner
Scanning does not stops
please check all sensor arms in the document feeder. The sensor arm in the middle just below the separation pad is called 'paper end sensor'. If this sensor arm is blocked or broken the scanner don't stop the feeder.
Another possibility is a driver error.
Jan 08, 2008 | Fujitsu M4097D IPC Path-Through Flatbed...
Error Code 009 Scanner out of paper
Right-click the VRS icon in the system tray. Select QC Modes and uncheck Hardware Errors. This will stop VRS from flashing the out of paper message.
(Also, ImageNow has it's own prompt when the scanner is empty. You can turn that off in the Scanning Profile on the Properties page.)
Oct 16, 2007 | Canon DR-9080C Path-Through Scanner
FI-5120c
Invalid orientation/long scan combination. Check the KScan ScanDirectionCap and ScanContinuousCap properties and set ScanDirection and ScanContinuous accordingly is for error 20080 and for 20090 means Peripheral stopped by user. Stop button was pressed.
Jul 31, 2007 | Fujitsu ScanPartner fi-5120C Pass-Through...
Getting error code Code[ffff:0024]while scanning
while i am trying to scan the images .. i am getting the error code like Code[ffff:0024] while warming up the scanner, besides a sound from the scanner making it power off (light inside the scanner goes off ) so that i could not get scanned anything ... what will be the reason ? please suggest me the trouble shoot kaarthik
Apr 14, 2007 | Acer Scan to Web 3300U Flatbed Scanner
Fujitsu fi-5530C Scanner Logo
181 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
