Question about Watches
Surface structure watch time set - Watches
I am looking for an instruction manual for a Structure watch 33415 model. There's an extra button or knob. What is it there for?
Fuzzy picture, but there are usually 4 buttons on a Sports Chronograph.
main knob pulls out and adjusts time, date and month depending on how far pulled out and which was turned.
one button is chrono start and stop
one button is split time
one button resets the dials back to zero.
I can't find a manual online
Dec 09, 2015 | Watches
Setting up the Surface 33416 watch.
sadly I would have to have it in my hand to tell you .
Nov 19, 2015 | Watches
Anyone have a manual for structure watch model 32441
Try typng structure watches in google search, there should be a website for that watch, then type in model number. You should be able to get a manual in this way.
Jun 09, 2014 | Watches
Can you help me set my surface watch model 33009
Are you sure the number 33009 is correct?
Most Wenger watches have 5-digit numbers starting with 7.
There is a Swiss Military Manual here:
https://www.wengerna.com/stuff/contentmgr/files/6/540159dc9885eeee1a65eec748ed4597/pdf/swiss_military_watch_manual_2012.pdf
May 07, 2014 | Wenger Swiss Military Classic Field Watch...
How do I set the digital time in my Surface 31874 watch?
When you press the Mode button:
1st press: FRI, SAT, SUN arrows flash. This is chronograph mode. Use START/STOP for stopwatch and RESET for split/clear.
2nd press: MON arrow flashes. This is where you set the alarm. Use START/STOP to advance number, and RESET to switch between minute and hour.
3rd press: TUE arrow flashes. This is where you set digital time. Seconds (in analog time window) flash first. Use START/STOP to reset seconds or advance number, and RESET to switch between seconds, minutes, hour, date day, and date month. Press mode again to exit. Have fun!
Oct 19, 2012 | Watches
Hour hand does not move minuet hand does not move but second works
Loose cannon pinion or cannon driving wheel, depending on model of movement inside the watch.
The seconds hand represents the wheels in the back of the watch going around ok, but the power need to transfer through to the front of the watch somehow. This is done by snapping/clicking two wheels together on either side of the main plate. The one on the dial side (cannon pinion) needs to slip to be able to set the time as the minute hand is set on this pinion. From there it is one wheel to the side & then back into the centre for the hour wheel. Over time the mating surfaces wear & become loose, meaning that the two hands driven fron the front of the watch are not being carried anymore. Time to see a repair guy!
Feb 14, 2011 | Watches
Hi, I have a casio protrek PRG-80T-7V(triple sensor). I haven't experienced any problems with it until recently. When I traveled abroad i passed through the ray gate in the airport wearing my watch....
Try to reset the watch.But first be sure that you capable of doing this.
Reseting the watch procedure:
1)Remove the back cover.Be sure that you have the appropriate screwdriver.Keep the 4 screws safe, not to loose them.
2)On the chassis of the watch (metallic surface) somewhere there is a hole with AC (All Clear) written nearby.
3)Use one little thin retracted paper clip (not totally retracted).Insert the retracted end of the clip into the hole, gently, until it touches the end and with the upper part of the clip contact the chassis (metallic surface). Wait for 1-2 sec and remove the clip gently.The watch is now reset.All functions have been set to factory settings.
4)Put back in place and with caution the back cover, respecting right (up-down) positioning and taking care that the O-ring gasket is well in place,first.
5)Holding in place with one finger the back cover,screw back screws gently and without applying excessive force (delicate job) until you meet resistance, in the following order:
Up-right,down-left,up-left,down-right.
After setting the time/day/date etc try to calibrate compass both ways as you did before.
I hope this will solve your problem.
NOTE:Again,be absolutely sure that you are capable of doing this.
It is a bit delicate job.If not,you better bring the watch to an official CASIO service center.
Apr 27, 2017 | Casio Protrek Triple Sensor PRG70 1BVDR...
Surface Watch Model 31819 How do you turn the alarm off?
I have a Surface Watch. Not sure if it's the same model number, but the button set up is the same. Here's what I did:
Hold down the bottom right button. While you're holding it down, press the top right button. My bottom right button doesn't seem to always work, so it made it rather difficult to figure out what has going on.
Dec 03, 2009 | Watches
I cannot set the date on my Citizen SkyHawk Eco-Drive
Just pull the crown out, turn it so that the bottom analog display is set on "CAL" and push crown back in. Voila!!
Mar 16, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Watches Logo
19 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
