2006 saturn veu
I replace the battery and the radio dosent turn on
3 Suggested Answers
  • 713 Answers
SOURCE: 2006 Saturn Vue, NoVin on radio display
sounds like the radio has lost it's programming might have to take to dealer to get the radio unlocked and reprogramed
Posted on Aug 30, 2009
airjer995
  • 5332 Answers
SOURCE: How to instal a rear bearing on a saturn veu 2002?auto repair
This would be a bolt on hub and bearing assembly. You will remove the wheel and the brake rotor or drum. Then unplug the abs sensor if equipped. Remove the axle nut if it's an all wheel drive (it is important to tighten the axle nut to the proper spec after replacing the bearing. Failure to properly torques the bearing will result in premature bearing failure). Remove the four bolts that hold the hub to the knuckle. Rmove the hub/bearing assembly.
Posted on Sep 04, 2012
Doom lights won't go out on a 2004 saturn veu can you help me?
The door ajar switch on the door latch in the drivers door is most likely defective.
Jan 27, 2017 | 2004 Saturn VUE
Having trouble with an aftermarket radio hrness in a 2001 saturn sl it wont turn on what can i do
the only 2 wires you dont want to cross are red and black . once you have red from radio red from harness, black from radio black from harness connected it should light up ..the speaker wires can be "trial and error" . if red and black together dosent light it up check the fuse on the radio and on incoming red wire. try bringing 2 wires straight from the battery with a fuse between the red one to radio,if it dosent light up then with "direct power " then the radio needs to come apart to see ether internal fuse or burnt our circuit. ps: sometimes you only need to connect the red "live" wire and touch the black on the casing of the radio to test for life.
May 01, 2015 | 2001 Saturn SL
2006 Saturn ION2 won't start. Happens every few
This is a very common problem with the Saturn. It's a bad ignition switch. You need to replace it.
Google on common saturn problems and you'll see that hundred of Saturn owners have had this very problem.
It's really amusing how each dealer prances around it and doesn't tell their customers that it's a common problem. If you bring it to them they will know right away what the problem is but they may pretend not to know right away...EVERY Saturn dealer has fixed this on dozens and dozens of their vehicles...
Dec 16, 2009 | 2006 Saturn ION
Aug 30, 2009 | Car Audio & Video
Radio preset buttons not working
you can take it to your mechanic. you might have to replace the entire radio set though
Jun 11, 2009 | 2006 Saturn ION
Radio not working after jump strart
You need a code to enable your radio. Happens every time the battery is dead or disconnected. Contact a Saturn rep.
May 21, 2009 | 2006 Saturn ION
DASHBOARD ENGING LIGHT (EMISSION LIGHT)
nothing really to do with your battery or coil pack.... if you happen to live in the states i hear that autozone will test the codes for free. have the codes tested and see what errors it shows.
Robert
Sep 13, 2008 | 2004 Saturn VUE
 Grubhead
Grubhead
