Question about GE Dryers
Viking GE 103 shredder needs mains cable rewiring
Mains cable pulled out of the machine
techbuster
  • 5081 Answers
SOURCE: Hi my washing machine wont stop running when the
Reason for taking a long time spinning is that it might have an uneven load. The wrong number of bath towels, for instance will mean it takes 3 or 4 tries at getting the spin right before it can spin them at the correct speed. An unbalanced load doesn't do the machine any good either.
After this wash has finished try it on something a lot lighter- say a duvet cover only with a couple of pillowcases. If that takes a long time too then the trouble is with the machine.
Looks like your "programmer" has stopped on the "spin cycle".
Could be a sensor has gone.
But everything points to the "little drive" in the programmer.
You could try "Manually Rotating The Selector Round a Few Times"
(This could free something off)
If a new "programmer" is needed, This could be more expensive than a new machine.
If the machine is under a year old it will still be under guarantee. If it is slightly over the year, but under 18 months old you still have a good case to go back to the manufacturer and get them to fix it.
Posted on Jul 03, 2009
SOURCE: electrolux z4494 vacuum cleaner mains cable wont stay out
Opened up case as follows:
- Open lid of bag chamber. Remove lid by gentry prising the hinge arms slightly further apart so the hing unclips from the body.
2 deeply recessed screws now accessible at rear edge of bag chamber - undo.
Prise out large button of on/off switch to reveal another screw - undo
Prise out large button of cable retract to reveal another screw - undo.
Cover now lifts off.
Inside I found the brake wheel had fallen out of its plastic bracket. The plastic bracket is hinged, and moved my pressing one end with the big button, which lifts the wheel away from the cable drum. Gently prised the bracket arms apart and put the brake wheel back in.
Solved it - but don't know why it happened, or whether it is likely to happen again.
Posted on Sep 02, 2009
  • 41 Answers
SOURCE: can this player have a mains cable and be able to play it without
Yes.
Posted on Oct 04, 2009
  • 980 Answers
SOURCE: need a mains lead
You need to either take a drawing of the plug on your machine and go to your l;ocal dealer if you have one or take the details off the motor
Posted on Apr 09, 2010
Samyfam
  • 379 Answers
SOURCE: How do I change the main cable to DC04 MAINS
Have a look at this link:
http://www.dysonmedic.com/DC04%20Folder/DC04%20Cable.html
Posted on Apr 27, 2010
Too much paper into shredder red light on paper is jammed
Some shredders have reverse mode
to eject jam. Otherwise its a slow job - Unplug from mains Remove each piece of paper as close to the jaws of the shredder as possible. Then hopefully when plug in and turn on will not find too much resistance and be able to cope with the paper and drag the jam through until clear.
May 25, 2016 | Shredder Office Equipment & Supplies
Not getting power at all
check AC - DC adapter could be faulty
Check surge protection if plugged into a surge protected powerboard
Could have a crook powerboard
May 27, 2015 | Computers & Internet
My Ativa HD Pro 1800 will not power on
First check the power point is still working - plug in another appliance, like a table lamp. If OK check the fuse in the shredder cable plug.
The commonest reason for a shredder stopping is a paper jam, or running the shredder for too long. By 'too long', many shredders will cut-out after 5 minutes continuous working, and the sensor may take 15 minutes to cool down! Read the manual.
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and/or long nosed pliers to poke at any compressed paper wrapped around the blades - can take a while.
It may be that the sensors are dirty - use a cotton bud dipped in rubbing alcohol to clean the sensor light(s) and heads
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
May 21, 2014 | Ativa HDM PRO 8000 8-Sheet Micro-Cut...
Shredder doesnt work
First check is the mains supply. Make sure the power point is live by trying another appliance in it. If OK check the mains cable is ok, again with another appliance if possible, or with a volt meter (borrow or visit an electrician) If all is still ok get in contact with your supplier
Apr 10, 2014 | Office Equipment & Supplies
On, Fwd, Rev button on my Shredmaster Model 75X stopped working. How do I fix this?
Check the mains supply is still on, and the fuse in the cable is ok.
Most problems are caused by james, and solved by removing the cover and unjamming the cutters. Can be tricky!
Apr 02, 2014 | Quartet gbc 75X Shredder
On, Fwd, Rvs button has stopped working on my Shredmaster 75X. How do I fix this?
Ativia hd pro 1400 wont turn on
Check the plug and fuse. Check that mains socket is live with another appliance.
Wile you are there, use a cotton bud dipped in rubbing alcohol to clean the sensor light(s) and heads
If all else fails, contact the maker
Jan 30, 2014 | Office Depot Ativa DQ60M Shredder
When I plug the TV in, the fuse blows. What could the problem be?
Inside your TV where the mains goes onto the main board is a capacitor network that stops interference from your TV going back to the mains supply. You may find that there is a short circuit there or the on off switch hs failed.
Dec 15, 2010 | Televison & Video
Fit cts to incoming mains supply with seperate metering
the ct's are place on the incoming wires by the power company. wires then pull off and go the seperate metering box. all of this is done by the power company
Sep 27, 2009 | General Electric GE ELECTRICAL TQD22200X2...
How to rewire a panasonic vacuum cleaner
Once you have taken the handle off and the front plastic cover below the handle at the front and above the bag/bucket holder, you gain access into the power cable and switch connections.
One wire will disconnect easily, the other won't, so instead of trying take this wire out of its connection where many others are from the switch and the motor, cut it on the mains lead before it enters the connection and reconnect the new mains lead wire with a **** or block connector, the other should connect normally with a spade connecter,making sure its will take the amperage of the v/cleaner
Hope this makes sense!
Sep 18, 2009 | Vacuums
Dryers Logo
26 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
