Question about Soleus Dehumidifier SG-DEH
Why does my dehumidifier trun on every time and then shut back off almost immediately?
Kenmore Elite 70 pint unit. Compressor appears to be frozen. Fan runs and compressor attempts to engage but immediately shuts down. Any suggestions. Unit is only about 2 years old.
Hi, I think you got it figured out...
There can be many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 15, 2010 | Kenmore 54501 Dehumidifier
Code CH 01 is showing where the humidity level is suppose to be. The machine turns on & shuts off immediately
Had same problem in 2008. Had to replace Evap Thermister board and sensor. Parts $120 Labor $50.00.
I am not an expert. Good Luck!
Aug 30, 2010 | Comfort-Aire BHD-651 Dehumidifier
Dehumidifier runs for approx. 15 min works fine then shuts off and doesn't come back on.
run it without the filter with a 1 part vinegar 4 parts water. then try it with a clean or new filter. You may need to run it a few (5-6) times before it stops shutting off by its self.
Aug 22, 2010 | Kenmore 54351 Dehumidifier
Kicks on then shuts off
check for a dirty condensor coil its by where the air comes out of it
Apr 08, 2010 | Goldstar DH504EL Dehumidifier
Fan quitting on unit
Maybe the room is dry enough so the humidity sensor is turning it off?
If not, maybe the thermisensor(fuse) on the fan motor is failing?
Jan 02, 2010 | Comfort-Aire BHD-501 Dehumidifier
My new Danby dehumidifier never shuts off
This unit is designed with the intention of the fan running all the time. The compressor cycles on and off with demand, however the fan runs continuously to provide constant room circulation.
Sep 14, 2009 | Dehumidifiers
Dehumidifier fan never shuts off. The only time
your humidistat is bad you can go to appliancepart pros.com and enter model number or call them they are really helpful
Jul 07, 2009 | Amana Dehumidifiers
The dehumidifier is blow cold air
Is it collecting water? The air coming out the back top half should be cool/warm. It will be a little warmer at the bottom near the compressor.
Apr 07, 2009 | Kenmore 54701 Dehumidifier
Soleus Dehumidifier SG-DEH Logo
65 people viewed this question
Top Soleus Dehumidifiers Experts
J.D. Browning
J.D. Browning
jeff5may32
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
