Central heating not responding to wireless thermostat. flashing red light on receiver next to programmer. ST9400C.
If press button to get green light, red light still flashes and heating will not turn off.
Buffalo12980
  • 625 Answers
SOURCE: installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Posted on Dec 07, 2007
  • 3 Answers
SOURCE: screen wont turn on - flashing green light
hello mark ,just had the same problem with my pioneer pdp503 hde, fixed myself and very easy to do. its the power supply board ,got mine on ebay for 109 pounds.was very easy to fit.it is the big silver panel in the center just unscrew and disconnect cabels. very commen problem in pdp . mark doran post again if you want more info
Posted on Jan 23, 2008
gamerfixer07
  • 344 Answers
SOURCE: PS3 does not turn on. When I press the on button, red light turns green thne to yellow then to flashing red.
This is called a System Error. It is about the same as the Xjunks ring of death. You need to call Sony if you haven't broken your seal yet.
Posted on Jun 25, 2008
SOURCE: New installed W.Bosch Greenstar 30CDi
one of my customers had the same fault recently. We tryed to reset the radio connection but, the appliance still did not respond.
The receiver was disconnected for the evening to prove boiler and system functionality which was ok.
Next day we installed new receiver & followed set up. customer has had no symptoms for 2 mnths.
Hope this helps.
Posted on Apr 21, 2009
satavlad
  • 405 Answers
SOURCE: My Receiver will not turn on
One of the channels is blown, it requires professional to look at it, if unit is under warranty just call onkyo.
Posted on Oct 30, 2009
Danfoss rx1 thermostat shows 'of' ?
Remove batteries from room stat,turn off the electrical supply to reciever unit.
Turn back on the electric to reciever unit,the red light should be on,press the top "manual" button,the green light should come on and boiler should fire (assuming the programmer is in an "on" period)
Press the bottom button,and keep it pressed,then press the top button until the green light flashes,stand about 6 feet away,and refit the batteries to the stat while observing the reciever unit,either the red or green light (cant remember which) should flash to show the 2 units are syncronised.
Another basic test if all seems ok,when turning the stat up or down,when the green light on the reciever unit comes on or goes off,its usually accompanied by an audible "click" ive found,that if this is not happening, the reciever unit does not switch either on or off,may be intermittant.
Replacement is the only cure.
garden led light
Jun 04, 2012 | Garden
Canon Color Bubble Jet Printer i550 wiil not print - (greenlight then orange light blinks 8x - then green light) When attempting to print receive "Printer not responding" - "Paper thickness lever...
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Office Equipment & Supplies
Remote not workin
what's happened here is the cm61 ng and the reciver box have lost there connection you will have to "rebind" them then it will be fine -
THE BINDING OPERATION DESCRIBED BELOW IS REQUIRED IF:
· Any of the system components (room unit or relay box) are replaced
· HC60NG has incorrect or no binding data stored (e.g. when pre-bound system pack components have been mismatched)
· Interference with the RF signal has caused a communication failure
During the binding procedure keep approximately 1m distance between the room unit and the HC60NG
1 Turn off mains supply to HC60NG for 10 seconds. Re-connect supply.
2 Press and hold the HC60NG push button for 15 seconds to reset previously stored data. The red LED will start to flash at 0.1 s on/0.9 s off. Release the push button.
3 Press and hold the HC60NG push button for 5 seconds to enter the binding mode. Red LED flashing at 0.5 s on/0.5 off confirms the binding mode has been entered.
4 Move the CM67NG slider to the OFF position (CM61 push the OFF button) and press the TEMP , TEMP and PROG 1 buttons together. The CM61/67NG will display InSt.
5 Press the i button to send the binding signal. The red LED is switched off on the receiver box to confirm the successful binding operation. If the red light still flashes push the repeat steps 1-3 and press the the i button until binding is successful.
hope this is helpful
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
New installed W.Bosch Greenstar 30CDi with DT20RF programmer. Have been getting intermittent cut out of heating when in progress as indicated on the programmer display by flashing green heating led and...
Hope this helps.
Oct 17, 2008 | Heating & Cooling
Installing a honeywell CM900 wireless programmable thermostat
Dec 04, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
