Question about RCA Microwave Ovens
Timer counts down but won't cook - RCA Microwave Ovens
MicrowaveSvc
  • 9098 Answers
SOURCE: timer will run, but won't cook
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 23, 2007
  • 17 Answers
SOURCE: Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
Posted on May 14, 2008
jeltey
  • 44 Answers
SOURCE: JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Posted on Nov 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Oven Does Not Start Cooking
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 25, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: TIMER COUNTS DOWN, MICROWAVE DOES NOT TURN ON
To actons2 - This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Note to Austin8181 - Your problem is not quite the same.
Please report as a separate request and of course please include your brand and model number.
Posted on Mar 06, 2009
Cook works microwave timer stuck
If by "manual timer" you are referring to a knob that you turn to set the cook time, then you may have a failure of the motor that turns the timing mechanism, or a lack of power to it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
May 10, 2014 | Microwave Ovens
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
Microwave door alignment is off, will count down but won't cook
My microwave will not heat up its in a defrost mode. How do I change it?
Jul 27, 2013 | Sharp R-1505 Microwave Oven
Kitchenaid KCMS185JSS
The problem is one of the door switches has failed, usually caused by food partical buildup, switch must be replaced for normal operation.
Mar 12, 2012 | KitchenAid Microwave Ovens
The timer counts down but the microwave doesnt turn on.
I have a FNCB115GC Microwave problem. The microwave has a icon on the left hand side of the panel that looks like a opened book on a stand with lines on top. This is best that I can descibe it. The microwave turntable does not move or the microwave does to come on but the light comes on and the timer will count down. I have cleared the microwave and unplugged it with no results. Please help. Thanks in advance.
Jun 03, 2010 | Frigidaire FMCB115GC Microwave Oven
Light on ,timer counting down but not turning or
See this file on door switches.
May 13, 2010 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
JVM1190 wont cook
Nov 09, 2008 | GE JVM1190 Microwave Oven
Frigidaire won't run
Aug 24, 2007 | Frigidaire FMV156EM Microwave Oven
Timer will run, but won't cook
Microwave Ovens Logo
Top RCA Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Andrew Taylor
Andrew Taylor
Are you a RCA Microwave Oven Expert? Answer questions, earn points and help others
