Question about Kohler Cimarron Comfort Height elongated 1.6 gpf toilet with Class Six tech
3323 Poor flush
Coffee maker 3323 russel hobbs on how to use it
Try Googling (Russell hobbs)(3323)(manual) without parens for instructions.
Jun 17, 2017 | Coffee Makers & Espresso Machines
Whine or squealing from tank when Kohler Santa Rosa toilet is flushed.
Sounds like an air lock is making the water fill in squeeze thru the piping. C if u can undo the piping from the tap below the tank and take out tank and try flushing the unit thru from the out side fill pipe. U may hv something stuck in the pipe line. cheers
Aug 25, 2012 | Kohler Santa Rosa K-3323-55 Innocent Blush...
I have to replace the gasket which the flush valve sits on. How do I remove the flush valve. The toilet is Kohler 1 piece model K-3323
The top of the pipe above the flush valve is threaded if you unscrew this you will be able to remove the flush valve and replace the gasket. I am assuming we are talking about the same here is a link that has all the parts:
http://www.plumbingsupply.com/kohlertoiletparts-santarosa.html
Oct 24, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
Just bought and just had installed a Santa Rosa toilet that will not shut off when filling. Found flush valve filling chamber to have a triangular hole close to base of cylinder. when you cover this...
I would say yes....here is the .pdf for your toilet and it has nothing like that in it...your toilet should be a simple fill device and flush mechanisim...
I would return it for a new one...
http://www.us.kohler.com/onlinecatalog/pdf/1066506_2.pdf
heatman101
Aug 05, 2010 | Kohler Santa Rosa K-3323-0 White Compact...
How install Kohler part no. 87988 in Santa Rosa
look under the tank, their should be a nut holding on the old one. by removing that nut the part should free itself.
Feb 27, 2010 | Kohler Santa Rosa K-3323-0 White Compact...
Toilet flushing sytem
your chain on your flapper is to long,adjust to proper hight.
Jul 15, 2009 | Kohler Santa Rosa K-3323-0 White Compact...
Howto install an auto detergent dispenser onto existing toilet ci
"Fluidmaster" makes a device that clips onto the tank and dispenses a solution into the bowl at each fill after a flush.
It goes inline with the tube runing from the fill valve, and dumps into the flush valve which goes into the bowl when filling.
Most LOWES carries them.
These are better than the ones that release the chemical into the tank because the chemical never has a chance of causing corrosion and failure of the tank to bowl seals.
Nov 18, 2008 | Kohler Santa Rosa K-3323-0 White Compact...
Tank will not refill after you flush
okay depending on the type of toilet ball **** (i know its a funny word, but it's really what its called.) you have one the most standard type is the long wire with the big ball on the end. you need to adjust this ball **** so it goes lower test it out, flush your toilett and wait till the water drains then when its supposed to come back up push down on the ball **** and youll see the water will start to fill, so then adjust the little screw on the fill valve (the other side of the floater where its attached)
you may need to shut off your water supply and drain your tank depending on how skilled you are,
pretty simple work, if you have questions feel free to ask.
Nov 16, 2008 | Kohler Santa Rosa K-3323-0 White Compact...
Printer wont respond
When you get to the printers and faxes window, did you check HP 3323 as your default printer?
Using your word processor (e.g. MS Word), click File, Print, and you get to the Print window, make sure that the Name of your printer is set to HP 3323. You may have installed other printers previously and it's still set to that printer.
Aug 26, 2008 | Computers & Internet
Kohler Cimarron Comfort Height elongated 1.6 gpf toilet with Class Six tech Logo
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
