Question about Dell DimensionTM E520 PC Desktop
No sound no audiono ethernet hard error c0000221
Windows xp if it will boot up after re istall
  • 790 Answers
Here is an explanation of your problem - http://support.microsoft.com/default...;en-us;Q314474
and ways of fixing it. Regards.
Download the file here http://www.dlldump.com/download-dll-.../download.html and replace the corrupted file .. it should be in C:\Windows\system32
When you boot up, go into Safe Mode (tap the f8 key as its starting to boot up and select Safe mode from the resulting menu). Now go to the 'problem' dll, right click on it and select rename. Rename it to ntdll.dll.old then paste the new .dll into the system32 file
Hope this helps
Posted on Apr 16, 2014
2 Suggested Answers
arnob01670
  • 22 Answers
SOURCE: "stop c0000221 unknown hard error
If you are getting this error when trying to reinstall from your XP cd, then it sounds like you have a loose damaged or incorrect cable to either your cdrom or hard drive. I suggest replacing them both with quality 80 wire 40 pin IDE cables. It can also be caused by incorrect configuration if you have RAID or SATA drives.
Finally you may want to try with just one stick of RAM installed. If you have more than one now; you should try each in the slot nearest the processor all by itself until you rule out one of them being bad (If it works with one stick and not the other, you know the other is bad).
There is more information on possible causes of this error at ahuma ; but my first suspicion on seeing the image checksum mismatch is that the file in question has been replaced with something else, a trojan or virus.
Please download
Mcafee stinger multivirus removal tool
Install and run
Thanks
Arnob
Posted on Apr 10, 2011
Please download
Install and run
Thanks
Arnob
Apr 10, 2011 | Dell Computers & Internet
Not booting, if boots thro' recovery cd produces c0000221 error and kernal 32.dll error.
There are errors on your hard drive. Contact www.toshiba.com for support.
Feb 17, 2011 | Toshiba Satellite A60 Notebook
WHEN I CUT ON MY LAPTOP..AFTER REINSTALLING WINDOWS XP.. ERROR ERROR FOR.. RELTEK RTL8139X/8130/10X PCI FAST ETHERNET CONTROLLER V2.13 020326 PXE-E61 MEDIA TEST FAILURE CHECK CABLE PXE-MOF EXITING...
the system is trying to boot to the Network adapter. If the system boots into Windows after the error, then all you need to do is change the boot sequence in the BIOS (Resetting defaults will likely fix this)
If system is not booting into windows after the error then you may have a hard drive fault
Sep 09, 2010 | Computers & Internet
Windows does not start automaticly it gives options like safe modeboot with the last knows config and start windows automaticly. When I click on any option the machine goes off and when I try to repair...
It may caused by the curreption(deletion) of important system files,
You can format and reinstall xp .
Restart computer when booting goes on press F5 Or DEL key to goto bios setup menu change boot order to first cd drive then hdd
PressF10 and press Y and enter.
computer will restart
Insert Xp cd.
Press enter to boot from cd
Follow the instructions
Then your problem will solve.
Jul 18, 2010 | Computers & Internet
STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
You may receive one of the following stop error messages while working on your Windows XP computer.
STOP: C0000221 unknown hard error
Path\File_nameSTOP: 0xC0000221 unknown hard error
C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
STOP: 0xC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH
Path\File_name
Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
<path>\<file_name>STOP: 0xC0000221 unknown hard error
c:\winnt\system32\ntdll.dll
Note: Some other drive may also be given in the message.
On Windows 2000 the following error message may display:
<path>\<file_name>
You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
Cause of the Error
This error occurs if the file given in the error message is damaged.
Your Windows XP operating system checks the following files for integrity during system startup:
  • All driver files, excluding the files that loaded using the system loader to start your system .
  • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
  • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
Resolution Method
You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
If this step does not resolve the problem, you may have to reinstall Windows XP.
It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
GOOD LUCK :-)
Feb 03, 2010 | Intel Computers & Internet
When i start my computer i get this message: stop: c0000221 UNKNOWN HARD ERROR /SYSTEMROOT/SYSTEM32/NTDLL.DLL what can i do?
I have a wipro laptop. i install windows Xp .But my system could show the operating system error . Then I am reinstalled Windows Xp. But the system will turnoff.
Dec 16, 2009 | Acer Aspire 5050-3242 Notebook
Help
Greetings,
When you upgrade your computer to Windows XP, you may receive an error message that is similar to one of the following: C0000221 (Bad Image Checksum)
-or- STOP: C0000221 - Bad Image Checksum in ModuleName
-or- STOP: C0000221 - Bad Image Checksum. User32.dll is possibly corrupt. The header check sum does not match the computed check sum.
Please go through the below mentioned link:
http://support.microsoft.com/kb/326687
Sep 20, 2009 | Microsoft Windows XP Professional for PC
C0000221 Unknown Hard Error\System32\ntdll.dll
From MS's KB:
http://support.microsoft.com/kb/314474
Feb 06, 2009 | Microsoft Office Professional 2007 Full...
Will not boot. The following (All greek to me) takes up about 1/2 of screen. toshiba hardware set-up Select pointing devices click simultaneous c0000221 bad image check sum shell 32....
the C0000221 error indicates a problem with the Windows File system.
This can often be caused by a failing hard drive. If your system has built in diagnostics (F12 at boot on many systems) you may be able to run a diagnostic there.
May 13, 2008 | Computers & Internet
Dell DimensionTM E520 PC Desktop Logo
43 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
